Component: SCADA (UART Dummy) (SCADA Slaves)
| Category | SCADA Slaves |
SCADA (UART Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / UART See Flowcode Help Wiki for firmware.
Please click here to view the component source code (Beta): FC_Comp_Source_OLD_API_Slave_UART_Dummy.fcfx
| IOGetInputPin | |
| Pin | |
| Range: 0-13 | |
| UARTBaud | |
| Rate | |
| UARTCheckRX | |
| UARTInitialise | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-13 | |
| State | |
| Range: 0-1 | |
| UARTReceive | |
| UARTSend | |
| Data | |
| Properties |
| IOGetInputPin | |
| Pin | |
| Range: 0-13 | |
| UARTBaud | |
| Rate | |
| UARTCheckRX | |
| UARTInitialise | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-13 | |
| State | |
| Range: 0-1 | |
| UARTReceive | |
| UARTSend | |
| Data | |
| Properties |
