Component: Webserver (EB023 v1) (E-blocks 1)
Revision as of 15:25, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
Webserver component
Webserver component designed to work with the NM7010A module from Wiznet, as used in the version 1 EB023 E-block. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here to download the component source project: FC_Comp_Source_WebServer_EB023-00-1_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer_EB023-00-1_EB.fcfx
Fc9-comp-macro.png SetOutValue
Fc9-u8-icon.png - BYTE index
Fc9-string-icon.png - STRING value
Fc9-comp-macro.png Send_Embedded_HTML_Page4
Fc9-comp-macro.png Send_Embedded_HTML_Page3
Fc9-comp-macro.png Send_Embedded_HTML_Page2
Fc9-comp-macro.png Send_Embedded_HTML_Page1
Fc9-comp-macro.png GetInValue
Fc9-comp-macro.png CreateServerSocket
Creates a listening socket on the selected channel and port ready to accept incoming web page requests.
Fc9-u8-icon.png - BYTE Port_Hi
Fc9-u8-icon.png - BYTE Port_Lo
Fc9-comp-macro.png IncRxPtr
Fc9-comp-macro.png CheckSocketActivity
Checks for activity on the server socket and serves out the webpages to any requesting parties.
Fc9-comp-macro.png Initialise
Fc9-type-10-icon.png Label
Fc9-type-14-icon.png Max Channels
Max number of concurrent channels allowed
Fc9-type-16-icon.png I2C Address
I2C address of the module - bit 0
Fc9-conn-icon.png HTML Source
Fc9-type-16-icon.png HTML Source
Sets the method for streaming data, we can either host it loacally using a property or refer to external files.
Fc9-type-14-icon.png Max Pages
Maximum number of pages we can serve using the embedded page type webserver.
Fc9-type-10-icon.png Name Page 1
Name of HTML page 1 - index.htm is the default page that will be presented.
Fc9-type-11-icon.png HTML Page 1
Embedded HTML code used for page 1
Fc9-type-10-icon.png Name Page 2
Name of HTML page 2
Fc9-type-11-icon.png HTML Page 2
Embedded HTML code used for page 2
Fc9-type-10-icon.png Name Page 3
Name of HTML page 3
Fc9-type-11-icon.png HTML Page 3
Embedded HTML code used for page 3
Fc9-type-10-icon.png Name Page 4
Name of HTML page 4
Fc9-type-11-icon.png HTML Page 4
Embedded HTML code used for page 4
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png Int Pin
Interrupt pin connection on Wiznet module
Fc9-conn-icon.png Gateway IP
Fc9-type-14-icon.png Gateway0
IP address of the gateway to the internet if applicable.
Fc9-type-14-icon.png Gateway1
Fc9-type-14-icon.png Gateway2
Fc9-type-14-icon.png Gateway3
Fc9-conn-icon.png Subnet Mask
Fc9-type-14-icon.png Subnet0
Subnet mask of the server - usually 255.255.255.0
Fc9-type-14-icon.png Subnet1
Fc9-type-14-icon.png Subnet2
Fc9-type-14-icon.png Subnet3
Fc9-conn-icon.png IP Address
Fc9-type-14-icon.png IP0
IP address of the server - usually 192.168.0.x or 192.168.1.x
Fc9-type-14-icon.png IP1
Fc9-type-14-icon.png IP2
Fc9-type-14-icon.png IP3
Fc9-conn-icon.png MAC Address
Fc9-type-14-icon.png MAC0
MAC address of the server
Fc9-type-14-icon.png MAC1
Fc9-type-14-icon.png MAC2
Fc9-type-14-icon.png MAC3
Fc9-type-14-icon.png MAC4
Fc9-type-14-icon.png MAC5
Fc9-conn-icon.png Substitutions
Fc9-conn-icon.png Outgoing
Fc9-type-16-icon.png Count
Fc9-type-21-icon.png Length 0
Fc9-type-21-icon.png Length 1
Fc9-type-21-icon.png Length 2
Fc9-conn-icon.png Incoming
Name of HTML page 2
Name of HTML page 3
Name of HTML page 4
Channel selection
Name of HTML page 2
Name of HTML page 3
Name of HTML page 4
Channel selection
