| Author
| Version
1.1
| Category
Misc
J1939 component
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
Check
| Returns 0 if running on an embedded target or 1 if running in simulation runtime.
- BOOL
Sim
Rx_Transfer_Data
| Returns the byte count and data of the transfer message data
- BYTE
DataBuffer
| Buffer to receive copied data
- UINT
Size
| Size (byte count) of buffer
- UINT
Message_Data_Read_SPN
| Read the SPN value from the CAN data buffer
- UINT
SPN
- BYTE
DataBuffer
- UINT
Process
| Does the message processing. Call this often.
- UINT
TimeElapsed
| Time elapsed since last call, in mS. Can be zero for frequent calling.
- BYTE
Rx_Transfer_Check
| Check for incoming multipart data transfers. If received, returns the PGN else 0
- ULONG
Get_Address
| Returns the device (ECU) actual address
- BYTE
Message_Data_Set
| Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF
- BYTE
DataBuffer
- BYTE
Value
Tx_Transfer_Send
| Send a mulitpart data transfer message. Returns number of bytes accepted. Limited by max message size.
- ULONG
PGN
| Multipart message program number
- BYTE
Data
| Data buffer to send
- UINT
Size
| Number of data bytes to send
- UINT
Rx_Message_Check
| If a data message has been received returns the PGN,otherwise 0
- UINT
Get_Status
| Returns the system status. 0 = Ready. 1 = Waiting address claim
- BYTE
Message_Data_Write_SPN
| Write the SPN value to the CAN data buffer
- UINT
SPN
- UINT
Value
- BYTE
DataBuffer
- BYTE
Rx_Message_Data
| Returns the DLC and data of the last received message
- BYTE
DataBuffer
- BYTE
Tx_Message_Send
| Send the prepared CAN message
- UINT
PGN
- BYTE
DLC
- BYTE
DataBuffer
- BYTE
Message_Data_Clear
| Clear the CAN Data Buffer
- BYTE
DataBuffer
Rx_Message_Source
| Returns the Source Address of the last received message
- BYTE
| Initialise the CAN network and J1939 protocol
- BYTE
Preferred_Address
| Preferred Address (Requested Address)
- BYTE
NAME
Industry Group
Vehicle System Instance
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
Transmit Message Buffer Size
| Byte buffer size to allocate for transmitted multipart messages. Maximum is 1785 or available RAM
Receive Message Buffer Size
| Byte buffer size to allocate for received multipart messages. Maximum is 1785 or available RAM
CAN
| Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Controller Osc
Bus Rate
| Data rate of the bus specified in thousand bits per second, Kbps.
SPI
CHANNEL
| SPI Channel selector
MOSI
MISO
CLK
SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Prescale
| Prescale option selector
Sample Point
| Data bit read sample point
Config Delay
Rx_Transfer_Data
- BYTE
DataBuffer
- UINT
Size
- UINT
- UINT
SPN
- BYTE
DataBuffer
- UINT
Process
- UINT
TimeElapsed
- BYTE
Rx_Transfer_Check
- ULONG
Get_Address
- BYTE
Message_Data_Set
- BYTE
DataBuffer
- BYTE
Value
Tx_Transfer_Send
- ULONG
PGN
- BYTE
Data
| Data buffer to send
- UINT
Size
- UINT
Rx_Message_Check
- UINT
Get_Status
- BYTE
- UINT
SPN
- UINT
Value
- BYTE
DataBuffer
- BYTE
Rx_Message_Data
- BYTE
DataBuffer
- BYTE
Tx_Message_Send
- UINT
PGN
- BYTE
DLC
- BYTE
DataBuffer
- BYTE
Message_Data_Clear
- BYTE
DataBuffer
Rx_Message_Source
- BYTE
- BYTE
Preferred_Address
- BYTE
NAME
Industry Group
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
CAN
Controller Osc
Bus Rate
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
Rx_Transfer_Data
- BYTE
DataBuffer
- UINT
Size
- UINT
- UINT
SPN
- BYTE
DataBuffer
- UINT
Process
- UINT
TimeElapsed
- BYTE
Rx_Transfer_Check
- ULONG
Get_Address
- BYTE
Message_Data_Set
- BYTE
DataBuffer
- BYTE
Value
Tx_Transfer_Send
- ULONG
PGN
- BYTE
Data
| Data buffer to send
- UINT
Size
- UINT
Rx_Message_Check
- UINT
Get_Status
- BYTE
- UINT
SPN
- UINT
Value
- BYTE
DataBuffer
- BYTE
Rx_Message_Data
- BYTE
DataBuffer
- BYTE
Tx_Message_Send
- UINT
PGN
- BYTE
DLC
- BYTE
DataBuffer
- BYTE
Message_Data_Clear
- BYTE
DataBuffer
Rx_Message_Source
- BYTE
- BYTE
Preferred_Address
- BYTE
NAME
Industry Group
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
CAN
Controller Osc
Bus Rate
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
Rx_Transfer_Data
- BYTE
DataBuffer
- UINT
Size
- UINT
- UINT
SPN
- BYTE
DataBuffer
- UINT
Process
- UINT
TimeElapsed
- BYTE
Rx_Transfer_Check
- ULONG
Get_Address
- BYTE
Message_Data_Set
- BYTE
DataBuffer
- BYTE
Value
Tx_Transfer_Send
- ULONG
PGN
- BYTE
Data
| Data buffer to send
- UINT
Size
- UINT
Rx_Message_Check
- UINT
Get_Status
- BYTE
- UINT
SPN
- UINT
Value
- BYTE
DataBuffer
- BYTE
Rx_Message_Data
- BYTE
DataBuffer
- BYTE
Tx_Message_Send
- UINT
PGN
- BYTE
DLC
- BYTE
DataBuffer
- BYTE
Message_Data_Clear
- BYTE
DataBuffer
Rx_Message_Source
- BYTE
- BYTE
Preferred_Address
- BYTE
NAME
Industry Group
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
CAN
Controller Osc
Bus Rate
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
