Component: GPS (EB056, Generic NMEA) (Wireless)
Revision as of 18:59, 16 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.1
Category Wireless
GPS (EB056, Generic NMEA) component
Component designed to process incoming NMEA style GPS data and convert into meaningful values such as longitude, lattitude, ground speed, UTC date and time. Also available in the form of the EB056 GPS E-block.
GPS Example File FC6 Icon.png GPS Example Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
GPS tracking application using an Arduino and an SD card reader. FC6 Icon.png GPS Tracker
Fc9-comp-macro.png ReadGroundSpeed
Returns the current ground speed. Only returns correct data if Log Ground Speed property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png ReadNumberOfSatellites
Returns the current detected number of satellites. Only returns correct data if Log Satellite Count property is set to yes.
Fc9-comp-macro.png ReadDilutionOfPrecision
Returns the current dilution of precision. Only returns correct data if Log Dilution Of Precision property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png CheckBufferOverflow
Returns the state of the buffer - 0 = OK, 1 = BufferTooShort, 2 = ItemNotFound. Only returns correct data if Log Buffer Overflow Property is set to Yes.
Fc9-comp-macro.png ReadLongitude
Returns the current longitude. Only returns correct data if Log Longitude property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png ReadUTCTime
Returns a segment of the current UTC Time. Only returns correct data if Log UTC Time property is set to yes.
Fc9-u8-icon.png - BYTE Unit
Specifies which segment to read - 'h', 'm', 's'
Fc9-comp-macro.png IsDataValid
Returns the state of the incoming data - 0 = NotValid, 1 = Valid 255 = No GPS Data Received.
Fc9-comp-macro.png ReadHorizontalDilutionOfPrecision
Returns the current horizontal dilution of precision. Only returns correct data if Log HDOP property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png ReadAltitude
Returns the current altitude. Only returns correct data if Log Altitude property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png ReadCourseOverGround
Returns the current course over ground. Only returns correct data if Log Course Over Ground property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png ReadUTCDate
Returns a segment of the current UTC Date. Only returns correct data if Log UTC Date property is set to yes.
Specifies which segment to read - 'd', 'm', 'y'
Fc9-comp-macro.png ReadVerticalDilutionOfPrecision
Returns the current vertical dilution of precision. Only returns correct data if Log VDOP property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png ReadLatitude
Returns the current latitude. Only returns correct data if Log Latitude property is set to yes.
[[File:]] - Return
Fc9-comp-macro.png Initialise
Initialises the UART used to communicate with the GPS module.
Fc9-comp-macro.png CardPlayback
Plays back a .Wav file audio stream from the card
Fc9-comp-macro.png ReadMic
Reads the microphone sensor 0 - 4095
Fc9-comp-macro.png ReadSwitch
Read the switch value
Fc9-u8-icon.png - BYTE index
0 (left) or 1 (right)
Fc9-comp-macro.png SampleAccel
Samples the accelerometer 0 = no new data, 1 = new data available
Fc9-comp-macro.png Left
Rotates the robot left - waits for the angle to be traversed before returning
Fc9-u16-icon.png - UINT Angle
Angle to turn in degrees
Fc9-comp-macro.png ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
Fc9-comp-macro.png LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
Fc9-u8-icon.png - BYTE X
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y
Y Pixel 0-31
Fc9-u8-icon.png - BYTE State
0=White (Off), 1=Black (On)
Fc9-comp-macro.png ServoSetPosition
Allows one of the servo positions to be assigned
Range 0-3
Fc9-u8-icon.png - BYTE Position
Range 0-255
Fc9-comp-macro.png CardBitmap
Displays a monochrome bitmap read from the card on the LCD
Range 0-127
Range 0-31
Fc9-comp-macro.png CardRecordMic
Records an audio stream on the card from the microphone
Fc9-u8-icon.png - BYTE BitDepth
0=8-bit, 1=16-bit
Fc9-u8-icon.png - BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
Fc9-u16-icon.png - UINT RecordTime
Time to record for in seconds, Range 0-65535
Fc9-comp-macro.png CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
Fc9-comp-macro.png Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
Fc9-u16-icon.png - UINT Distance
Distance in mm
Fc9-comp-macro.png ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
[[File:]] - Return
Fc9-comp-macro.png LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
Fc9-u8-icon.png - BYTE X1
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y1
Y Pixel 0-31
Fc9-u8-icon.png - BYTE X2
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y2
Y Pixel 0-31
Fc9-comp-macro.png ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
Range 0-3
Range 0-255
Fc9-comp-macro.png ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
Fc9-u8-icon.png - BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
Fc9-comp-macro.png LCDBacklight
Allows the LCD backlight brighntess to be adjusted
Fc9-u8-icon.png - BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
Fc9-comp-macro.png LCDDrawRect
Allows a rectangle to be drawn on the LCD
X Pixel 0-127
Y Pixel 0-31
X Pixel 0-127
Y Pixel 0-31
Fc9-comp-macro.png ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
0=Left, 1=Right
Fc9-comp-macro.png ServoDisable
Allows one of the servo outputs 0-3 to be disabled
Range 0-3
Fc9-comp-macro.png ServoEnable
Allows one of the servo outputs 0-3 to be enabled
Range 0-3
Fc9-comp-macro.png CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
Fc9-comp-macro.png CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the currently open file
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
0=Left, 1=Right
Fc9-comp-macro.png SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Fc9-comp-macro.png Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
Distance in mm
Fc9-comp-macro.png EncoderReset
Resets the motor encoder counters
Fc9-comp-macro.png LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
0=Off 1=On
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-comp-macro.png LCDClear
Clears the LCD
The maximum number of bytes of a NMEA message we can store before processing the message.
Fc9-type-7-icon.png Log Altitude
Adds a variable to store the incoming altitude value Referenced by macro: ReadAltitude
Fc9-type-7-icon.png Log Buffer Overflow
Adds a variable to store if the incoming message buffer overflows Referenced by macro: CheckBufferOverflow
Fc9-type-7-icon.png Log Course Over Ground
Adds a variable to store the incoming course over ground value Referenced by macro: ReadCourseOverGround
Fc9-type-7-icon.png Log Dilution Of Precision
Adds a variable to store the incoming DOP value Referenced by macro: ReadDilutionOfPrecision
Fc9-type-7-icon.png Log Ground Speed
Adds a variable to store the incoming ground speed value Referenced by macro: ReadGroundSpeed
Fc9-type-7-icon.png Log Horizontal DOP
Adds a variable to store the incoming HDOP value Referenced by macro: ReadHorizontalDilutionOfPrecision
Fc9-type-7-icon.png Log Latitude
Adds a variable to store the incoming latitude value Referenced by macro: ReadLatitude
Fc9-type-7-icon.png Log Longitude
Adds a variable to store the incoming longitude value Referenced by macro: Read Longitude
Fc9-type-7-icon.png Log Satellite Count
Adds a variable to store the number of satellites in range Referenced by macro: ReadNumberOfSatellites
Fc9-type-7-icon.png Log UTC Time
Adds a variable to store the incoming UTC Time value Referenced by macro: ReadUTCTime
Fc9-type-7-icon.png Log UTC Date
Adds a variable to store the incoming UTC Date value Referenced by macro: ReadUTCDate
Fc9-type-7-icon.png Log Verticle DOP
Adds a variable to store the incoming VDOP value Referenced by macro: ReadVerticalDilutionOfPrecision
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Fc9-type-7-icon.png Show Globe
Allows a graphical globe to be shown on the panel along with a coordinate marker.
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
