| Author | MatrixTSL |
| Version | 0.1 |
| Category | Comms |
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak via WebSockets.  Allows IoT type data to be published and read back.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_MQTT.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_MQTT.fcsx
Connect
|   | Connect |
| Connects to the MQTT server (returns false if already connected) |
|  - BOOL | Return |
Disconnect
|   | Disconnect |
| Disconnect from the MQTT server (returns false if client is already disconnected) |
|  - BOOL | Return |
GetClientId
|   | GetClientId |
| Returns the unique identifier currently used when communicating with the server. |
|  - STRING | Return |
Publish
|   | Publish |
| Publish a message to the MQTT server (returns false in the client is not connected) |
|  - STRING | Topic |
| The name of the topic for the message |
|  - STRING | Message |
| The message to publish |
|  - BYTE | QoS |
| The quality of service used to deliver the message (0, 1 or 2) |
|  - BOOL | Retained |
| If true. the message is to be retained by the server and delivered to future subscribers as well as current ones |
|  - BOOL | Return |
PublishBuffer
|   | PublishBuffer |
| Publish an array of bytes to the MQTT server (returns false in the client is not connected) |
|  - STRING | Topic |
|  - HANDLE | Buffer |
| The message to publish (as an array buffer) |
|  - BYTE | QoS |
|  - BOOL | Retained |
|  - BOOL | Return |
Subscribe
|   | Subscribe |
| Subscribe to messages from the MQTT server (returns false in the client is not connected) |
|  - STRING | Topic |
| A filter for the topic name(s) to receive |
|  - BYTE | QoS |
|  - BYTE | Timeout |
| The number of seconds to wait before assuming this operation failed |
|  - BOOL | Return |
Unsubscribe
|   | Unsubscribe |
| Unsubscribe from messages from the MQTT server (returns false in the client is not connected) |
|  - STRING | Topic |
| A filter for the topic name(s) to stop receiving |
|  - BYTE | Timeout |
|  - BOOL | Return |
|   | Properties |
|   | Host |
| The address of the messaging server, as a fully qualified WebSocket URI, as a DNS name or dotted decimal IP address |
|   | Port |
| The port number to connect to |
|   | Directory |
| An optional subdirectory off the host address (e.g. "/mqtt") |
|   | Client Id |
| A unique identifier for this client, between 1 and 23 characters in length |
|   | Advanced |
|   | Use SSL |
| Use a secure (SSL) connection |
|   | Use authentication |
|   | Connection timeout |
| If connection has not succeeded within this time (in seconds), it is deemed to have failed |
|   | Keep Alive Interval |
| The server will disconnect this client if there is no activity for this time period (in seconds) |
|   | Clean Session |
| If true, a non-persistent connection is created, meaning subscription information and undelivered messages are not retained when this connection ends |
|   | Reconnect |
| If true, this client will attempt to reconnect to the server if the connection is lost |
|   | Send LWT |
| Send a 'Last Will and Testament' message if unexpected disconnection occurs |
|   | MQTT Version |
| Which version of MQTT to use |
|   | Debug |
| Determines if additional logging information is sent to the JavaScript console |
|   | Callbacks |
|   | OnSuccess |
| Called when an MQTT operation is successful |
|   | OnFailure |
| Called when an MQTT operation is unsuccessful |
|   | OnConnected |
| Called when an MQTT connection is successfully made to the server |
|   | OnConnectionLost |
| Called when an MQTT connection has been lost |
|   | OnMessageDelivered |
| Called when an MQTT message has been delivered |
|   | OnMessageArrived |
| Called when an MQTT message has arrived at this client |
