Component: GSM (EB066, Generic AT) (Wireless)
| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Wireless |
GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
| DialNumber | |
| Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response. | |
| Number | |
| GetTextString | |
| Collects the text message data from an incoming text message. | |
| NumBytes | |
| SendString | |
| Sends a string to the GSM module. | |
| Text | |
| SendScript | |
| Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx. | |
| idx | |
| SendCommand | |
| Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply | |
| Command | |
| SendCR | |
| AnswerIncomingCall | |
| Answers the phone for an incoming type call. Returns 0 for success and 255 for failure. | |
| GetTextNumber | |
| Collects the sender's phone number from an incoming text message. | |
| NumBytes | |
| HangUpCall | |
| Ends a voice based call. Returns 0 for success and 255 for failure. | |
| ReadString | |
| Copies the data from the data string array to a local string variable | |
| NumBytes | |
| SendTextMessage | |
| Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure. | |
| Number | |
| Message | |
| StringReceive | |
| Attempts to receive a string from the GSM modem. | |
| DeleteAllMessages | |
| Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail. | |
| CheckNetworkStatus | |
| Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM. | |
| CheckForIncoming | |
| Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing | |
| Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail. | |
| ReadMic | |
| Reads the microphone sensor 0 - 4095 | |
| ReadSwitch | |
| Read the switch value | |
| index | |
| 0 (left) or 1 (right) | |
| SampleAccel | |
| Samples the accelerometer 0 = no new data, 1 = new data available | |
| Left | |
| Rotates the robot left - waits for the angle to be traversed before returning | |
| Angle | |
| Angle to turn in degrees | |
| LCDDrawPixel | |
| Allows a single pixel on the LCD to be set or cleared | |
| X | |
| X Pixel 0-127 | |
| Y | |
| Y Pixel 0-31 | |
| State | |
| 0=White (Off), 1=Black (On) | |
| ServoSetPosition | |
| Allows one of the servo positions to be assigned | |
| Channel | |
| Range 0-3 | |
| Position | |
| Range 0-255 | |
| CardBitmap | |
| Displays a monochrome bitmap read from the card on the LCD | |
| X | |
| Range 0-127 | |
| Y | |
| Range 0-31 | |
| Filename | |
| CardOpen | |
| Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
| Filename | |
| Forwards | |
| Drives the robot forwards - waits for the distance to be traversed before returning | |
| Distance | |
| Distance in mm | |
| ReadBearing | |
| Reads the compass bearing based on the degrees clockwise from magnetic north. | |
| [[File:]] - | Return |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| LCDDrawLine | |
| Allows a single pixel width line to be drawn on the LCD | |
| X1 | |
| X Pixel 0-127 | |
| Y1 | |
| Y Pixel 0-31 | |
| X2 | |
| X Pixel 0-127 | |
| Y2 | |
| Y Pixel 0-31 | |
| ServoAutoMoveToPosition | |
| Allows one of the servo positions to move gradually to a new position | |
| Channel | |
| Range 0-3 | |
| Position | |
| Range 0-255 | |
| ReadAllValue | |
| Reads a single value stored from the read all command Index dictates which sensor value to read | |
| Index | |
| 0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
| LCDBacklight | |
| Allows the LCD backlight brighntess to be adjusted | |
| Intensity | |
| Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
| LCDDrawRect | |
| Allows a rectangle to be drawn on the LCD | |
| X1 | |
| X Pixel 0-127 | |
| Y1 | |
| Y Pixel 0-31 | |
| X2 | |
| X Pixel 0-127 | |
| Y2 | |
| Y Pixel 0-31 | |
| ReadLine | |
| Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
| index | |
| 0=Left, 1=Right | |
| ServoDisable | |
| Allows one of the servo outputs 0-3 to be disabled | |
| Channel | |
| Range 0-3 | |
| ServoEnable | |
| Allows one of the servo outputs 0-3 to be enabled | |
| Channel | |
| Range 0-3 | |
| CardReadByte | |
| Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
| CardErase | |
| Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
| Filename | |
| CardWriteByte | |
| Appends a byte to the end of the currently open file | |
| Data | |
| EncoderRead | |
| Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
| index | |
| 0=Left, 1=Right | |
| SetMotors | |
| Sets the motor speeds without feedback Range -100 to 100 | |
| [[File:]] - | Left |
| [[File:]] - | Right |
| Backwards | |
| Drives the robot backwards - waits for the distance to be traversed before returning | |
| Distance | |
| Distance in mm | |
| EncoderReset | |
| Resets the motor encoder counters | |
| LCDVerbose | |
| Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
| State | |
| 0=Off 1=On | |
| SetProp | |
| Allows the COM port property to be set from a parent component. | |
| PropName | |
| PropVal | |
| CardInit | |
| Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
| GetProp | |
| Allows the property filter for the COM port list to be copied to a parent component. | |
| PropName | |
| LCDClear | |
| Clears the LCD | |
