Component: GLCD (SSD1305) (SSD1305) (Graphical Monochrome)
Revision as of 10:42, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.8
Category Graphical Monochrome
GLCD (SSD1305) component
Graphical display component based on the SSD1305 monochrome graphical controller IC.
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
[[File:]] - Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Fc9-u8-icon.png - BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
Fc9-u8-icon.png - BYTE Waveform
Fc9-comp-macro.png CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
Fc9-comp-macro.png MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
Fc9-comp-macro.png MSTLOCK
Sends signal to SLAVE generator to get synchronised
Fc9-comp-macro.png HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
Fc9-comp-macro.png ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
Fc9-u16-icon.png - UINT Waveform
Fc9-comp-macro.png WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
Fc9-u8-icon.png - BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
Fc9-comp-macro.png CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
Fc9-comp-macro.png STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
Fc9-comp-macro.png ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
Fc9-comp-macro.png EERRet
Query and clear execution error number register.
Fc9-comp-macro.png MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Fc9-comp-macro.png ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
Fc9-u8-icon.png - BYTE Value
Value of register 0-255
Fc9-comp-macro.png ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
16 Bit binary number for arbitrary waveform.
Fc9-comp-macro.png ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
Fc9-comp-macro.png CLS
Clears status byte register of the interface.
Fc9-comp-macro.png MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
Fc9-comp-macro.png NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
Fc9-u8-icon.png - BYTE Percent
Sets the output noise level in percent. (0 - 50)
Fc9-comp-macro.png LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
Fc9-u8-icon.png - BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
Fc9-comp-macro.png ADDRESSRet
Returns the instruments address
[[File:]] - Return
Fc9-comp-macro.png MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
Fc9-u8-icon.png - BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
Fc9-comp-macro.png ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
Fc9-comp-macro.png LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
Fc9-comp-macro.png OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
Fc9-comp-macro.png SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
Fc9-u8-icon.png - BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
Fc9-comp-macro.png PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
Fc9-u8-icon.png - BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
Fc9-comp-macro.png TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
Fc9-comp-macro.png BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
Fc9-comp-macro.png BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
Fc9-comp-macro.png IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
Fc9-string-icon.png - STRING ReturnIDN
Fc9-comp-macro.png SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
Fc9-comp-macro.png PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Opens the COM port ready for communications.
Fc9-type-21-icon.png H Offset
Offset from the edge of the display, default 0.
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Display Method
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Read / Write (R/W)
Fc9-type-5-icon.png Reg Select (RS)
Fc9-type-5-icon.png Data (SD)
Fc9-type-5-icon.png Serial Clock (SCK)
Reset pin connection
Fc9-type-5-icon.png Reset (RST)
Fc9-conn-icon.png Simulations
