Component: PicoScope (PS2000) (Test Equipment)
Revision as of 11:05, 17 November 2021 by Wiki bot (talk | contribs)
Category Test Equipment
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
Velleman and Picoscope Demo
ps2000_get_timebase
Returns details associated with the selected timebase index
[[File:]] - Handle
the handle of the required device.
[[File:]] - timebase
The ps2000a API allows you to select any of 2 32 different timebases based on a maximum sampling rate of 1 GS/s.
[[File:]] - no_of_samples
number of samples required
[[File:]] - time_interval
time interval between readings at the selected timebase. Use NULL if not required.
[[File:]] - time_units
[[File:]] - oversample
not used.
[[File:]] - max_samples
on exit, the maximum number of samples available.
[[File:]] - Return
ps2000_open_unit_progress
This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope.
[[File:]] - handle
[[File:]] - Progress
[[File:]] - Return
ps2000_flash_led
This function flashes the LED on the front of the scope without blocking the calling thread.
[[File:]] - handle
handle of the scope device
[[File:]] - Return
ps2000_stop
This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data.
[[File:]] - Handle
[[File:]] - Return
ps2000_get_unit_info
This function retrieves information about the specified oscilloscope.
[[File:]] - Handle
the handle of the device
- STRING info_string
unit information string
[[File:]] - string_length
the maximum number of chars in the string
[[File:]] - info_line
a number specifying what information is required. 0=DriverVersion / 1=USBVersion / 2=HardwareVersion / 3=VariantInfo / 4=BatchAndSerial / 5=CalDate / 6=KernelVersion / 7=DigHardwareVersion / 8=AnHardwareVersion
[[File:]] - Return
ps2000_set_channel
This function specifies whether an input channel is to be enabled, its input coupling type, voltage range, analog offset and bandwidth limit.
[[File:]] - handle
Handle of the device
[[File:]] - channel
the channel to be configured. The values are: 0=ChanA / 1=ChanB
[[File:]] - enabled
whether or not to enable the channel. The values are: 0=Disable / 1=Enable
[[File:]] - dc
the impedance and coupling type. Values: 0=AC / 1=DC
[[File:]] - range
the input voltage range: 0=50mV / 1=100mV / 2=200mV / 3=500mV / 4=1V / 5=2V / 6=5V / 7=10V / 8=20V
[[File:]] - Return
ps2000_get_times_and_values
[[File:]] - Handle
[[File:]] - times
[[File:]] - buffer_a
[[File:]] - buffer_b
[[File:]] - buffer_c
[[File:]] - buffer_d
[[File:]] - overflow
[[File:]] - Return
ps2000_set_trigger
[[File:]] - handle
[[File:]] - source
[[File:]] - threshold
[[File:]] - direction
[[File:]] - delay
[[File:]] - auto_trigger_ms
[[File:]] - Return
ps2000_set_sig_gen_built_in
sets up the signal generator to produce a signal from a list of built-in waveforms
[[File:]] - Handle
Handle to the device
[[File:]] - Offset_uV
the voltage offset, in microvolts, to be applied to the waveform
- ULONG pk2pk_uV
the peak-to-peak voltage, in microvolts, of the waveform
[[File:]] - waveType
the type of waveform to be generated. 0=Sine / 1=Square / 2=Triangle / 3=RampUp / 4=RampDown / 5=Sinc / 6=Gaus / 7=HalfSine / 8=DC
[[File:]] - startFrequency
the frequency that the signal generator will initially produce
[[File:]] - stopFrequency
the frequency at which the sweep reverses direction or returns to initial
[[File:]] - increment
the amount of frequency increase or decrease in sweep mode
[[File:]] - dwellTime
the time for which the sweep stays at each frequency, in seconds
[[File:]] - sweepType
whether the frequency will sweep from startFrequency to stopFrequency. 0=Up, 1=Down, 2=UpDown, 3=DownUp
- ULONG sweeps
produce number of cycles specified by shots
[[File:]] - Return
ps2000_close_unit
This function shuts down an oscilloscope.
[[File:]] - Handle
The handle of the scope device to be closed
[[File:]] - Return
ps2000_run_block
This function starts collecting data in block mode.
[[File:]] - handle
[[File:]] - time_indisposed_ms
[[File:]] - Return
ps2000_get_values
This function returns block-mode data, with or without downsampling.
[[File:]] - Handle
Start point for data collection
Number of samples
Down sample ratio
Down sample mode : 0=None / 1=Aggregate / 2=Decimate / 4=Average
Flags to indicate if an overflow has occurred
[[File:]] - Return
ps2000_ready
[[File:]] - Handle
[[File:]] - Return
ps2000_open_unit_async
This function opens a scope without blocking the calling thread.
[[File:]] - Return
ps2000_open_unit
Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open
[[File:]] - Return
Simulations
