| Author
Matrix Ltd
| Version
2.0
| Category
Graphical Library
Touch Screen (XPT2046) component
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found on a lot of common low cost resistive touch screen products.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_XPT2046.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_XPT2046.fcfx
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller.
GLCD 4.3 Touch
Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller.
GLCD 7 Touch
SampleSensor
| Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Touch in progress
  - BYTE
ReadCoord
| Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
  - BYTE
Coordinate
| 0 = X, 1 = Y, 2 = Pressure
  - UINT
| Activates the SPI peripheral and claims control over the I/O pins.
LinkTo
Bus Settings
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin  Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
| Label used to identify the component on the panel.
Enable Interrupt
| Allows the simulated display to fire an interrupt to allow you to action inputs as they happen.
Interrupt Macro
| Macro called when the simulated display fires an interrupt.
Simulate Comms
| Allows the SPI communications to be simulated and piped through an API to real world hardware.
SampleSensor
  - BYTE
ReadCoord
  - BYTE
Coordinate
  - UINT
LinkTo
Bus Settings
Prescale
MOSI
MISO
CLK
CS / SS
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
Enable Interrupt
Interrupt Macro
Simulate Comms
SampleSensor
  - BYTE
ReadCoord
  - BYTE
Coordinate
  - UINT
LinkTo
Bus Settings
Prescale
MOSI
MISO
CLK
CS / SS
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
Enable Interrupt
Interrupt Macro
Simulate Comms
SampleSensor
  - BYTE
ReadCoord
  - BYTE
Coordinate
  - UINT
LinkTo
Bus Settings
Prescale
MOSI
MISO
CLK
CS / SS
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
Enable Interrupt
Interrupt Macro
Simulate Comms
