Component: RMT (Internal) (Misc)
Revision as of 10:23, 24 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
RMT (Internal) component
Provides access to the onboard remote control (RMT) peripheral allowing for high speed data input / output without requiring bit banging from the ESP32 processor.
Please click here to download the component source project: FC_Comp_Source_RMT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RMT.fcfx
Fc9-comp-macro.png Initialise
Initialises the RMT module ready for data to be sent or received.
SetBuffer
Fc9-comp-macro.png SetBuffer
Writes data to the RMT buffer
Fc9-u16-icon.png - UINT Index
Array index, Range: 0 - (BufferSize - 1)
Fc9-bool-icon.png - BOOL State0
The first state to output
Fc9-u16-icon.png - UINT Length0
The length of the first output state in divided clock periods
Fc9-bool-icon.png - BOOL State1
The second state to output
Fc9-u16-icon.png - UINT Length1
The length of the second output state in divided clock periods
Transmit
Fc9-comp-macro.png Transmit
Sends out the RMT data buffer.
Fc9-u8-icon.png - BYTE WaitWhileComplete
0=Dont Wait, 1=Wait for TX to complete
TransmitBusy
Fc9-comp-macro.png TransmitBusy
Checks to see if the RMT channel is currently transmitting. Returns 1 if transmitting and 0 if transmission is complete.
Fc9-type-16-icon.png Mode
Controls if we are transmitting or receiving data
Fc9-type-5-icon.png Pin
Pin to assign the RMT functionality
Fc9-type-21-icon.png Clock Divider
Base Clock speed is 80MHz. Div by 1 = 80MHz Div by 2 = 40MHz Div by 4 = 20MHz Div by 8 = 10MHz
Fc9-type-16-icon.png Mem Block Num
Starting RMT memory block
Number of values inside the data buffer, 64 = 1 Block A buffer size of 128 would consume two sequential blocks of memory. If starting at block 1 then you can have a maximum buffer size of 512 consuming all 8 blocks.
Fc9-conn-icon.png Tx Properties
Fc9-type-7-icon.png TX Loop Enable
Allows the transmit buffer to be constantly looped.
Fc9-type-7-icon.png TX Carrier Enable
Enables a carrier frequency to be overlaid on the transmitted data
Fc9-type-7-icon.png TX Idle Output
When not transmitting should the Transmit pin be an active output?
Fc9-type-16-icon.png TX Idle Level
Sets the output state when idle.
