Component: Data Queue to Bits (DSP Inputs)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.2 |- | width="20%" style="color:gray...")
Version 1.2
Category DSP Inputs
Data Queue to Bits component
Allows data to be loaded into a buffer and then output a bit at a time into the DSP system. Useful for things like communications where data is modulated and sent out a bit at a time.
Please click here to download the component source project: FC_Comp_Source_DSP_DataToBits.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_DataToBits.fcfx
CountQueueData
Fc9-comp-macro.png CountQueueData
Returns the number of data bytes/bits remaining in the queue. The bit count includes start/stop bits.
Fc9-bool-icon.png - BOOL CountBits
0=Return Byte Count, 1=Return Bit Count
FetchNextDataBit
Fc9-comp-macro.png FetchNextDataBit
Gets the next stored bit from the data queue. If the data queue is empty then returns the default state.
QueueByte
Fc9-comp-macro.png QueueByte
Adds a single byte value to the data buffer.
Fc9-u8-icon.png - BYTE Data
QueueByteArray
Fc9-comp-macro.png QueueByteArray
Adds an array of byte values to the data buffer.
Fc9-u16-icon.png - UINT Count
QueueFloat
Fc9-comp-macro.png QueueFloat
Adds a single float value to the buffer. A 32-bit Float value occupies 4-bytes in the buffer.
Fc9-f32-icon.png - FLOAT Data
QueueFloatArray
Fc9-comp-macro.png QueueFloatArray
Adds an array of float values to the data buffer. A 32-bit Float value occupies 4-bytes in the buffer.
QueueInt
Fc9-comp-macro.png QueueInt
Adds a single integer value to the data buffer. A 16-bit integer value occupies 2-bytes in the buffer.
Fc9-u16-icon.png - UINT Data
QueueIntArray
Fc9-comp-macro.png QueueIntArray
Adds an array of integer values to the data buffer. A 16-bit integer value occupies 2-bytes in the buffer.
QueueLong
Fc9-comp-macro.png QueueLong
Adds a single long value to the data buffer. A 32-bit integer value occupies 4-bytes in the buffer.
Fc9-u32-icon.png - ULONG Data
QueueLongArray
Fc9-comp-macro.png QueueLongArray
Adds an array of long values to the data buffer. A 32-bit integer value occupies 4-bytes in the buffer.
QueueString
Fc9-comp-macro.png QueueString
Adds an string of characters to the data buffer.
Fc9-conn-icon.png DSP Buffer Properties
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Fc9-conn-icon.png Data Queue Properties
Fc9-type-21-icon.png Queue Size
Sets the number of byte elements inside the circular buffer.
Fc9-type-14-icon.png Logic 1 Value
Value passed to the DSP buffer used to represent a set bit in the data queue.
Fc9-type-14-icon.png Logic 0 Value
Value passed to the DSP buffer used to represent a clear bit in the data queue.
Fc9-type-21-icon.png Tick Divider
Sometimes you will not want a new data bit every DSP tick. The Tick Divider property allow you to set how many DSP ticks to wait before fetching the next bit from the data buffer.
Fc9-type-16-icon.png Data Order
Selects the bit order to allow the most significant or least significant bit to be sent first.
Fc9-type-16-icon.png Default State
Value used when the data queue is empty
Fc9-type-16-icon.png Data Format
Decides if each byte is sent out as 8-bit, 9-bit or 10-bit packets. The 9-bit and 10-bit packet types will include a start bit that is opposite to the default state. The 10-bit packet types will also include a stop bit that is the same as the default state.
