Component: Power Board (BL0110) (E-blocks 2)
Revision as of 08:58, 9 June 2025 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category E-blocks 2
Power Board (BL0110) component
A component to drive the power board BL0110 either as a full bridge or as two half bridges.
Disable
Disable
Enable
Enable
SetDirection
SetDirection
Allows the direction of current to be reversed. Only applies to the Full Bridge mode.
- BOOL Direction
0=Forwards, 1=Reverse
SetDuty
SetDuty
- BYTE Channel
0=A, 1=B
- UINT Duty
Range: 0 to Resolution - 1
Setup
Mode
Defines how the driver is connected. A full bridge is capable of controlling a load like a DC motor offering speed and direction control. A half bridge is capable of controlling a load like a DC motor with speed control only.
PWM A
Enable A
PWM B
Enable B
Timer Properties
Timer
Timer Peripheral to use to monitor the passage of time.
Frequency (Hz)
Sets the control frequency of the PWM output. Recommend between 100 and 5000 Hz
Resolution
Defines how many possible steps there are in the output PWM duty. Recommend 100 - 256 100 would allow for duty control values in the range of 0 (fully off) to 99 (fully on)
Interrupt Rate (Hz)
The overall timer interrupt rate. Try to keep this as low as possible to avoid slowing down the system with excessive interrupts.
Please click here to download the component source project: FC_Comp_Source_Eblocks2_Power_BL0110.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Eblocks2_Power_BL0110.fcfx
