| Author
Matrix TSL
| Version
1.2
| Category
Mechatronics
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Version information
2, 1.2, 13-11-24, BR, Altered property tooltips to make them more meaningful
Simple example showing how to drive the motor component by only using Enable and two port pins.
DC Motor pin control
Break
Break
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Coast
Coast
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Disable
Disable
| Disable the motor output
Enable
Enable
| Enables the motor output
Forwards
Forwards
| Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
- UINT
Duty
| Sets the motor power for PWM or H-Bridge outputs
GetSimAngle
GetSimAngle
| Gets the angle of the simulated motor shaft in degrees.
- FLOAT
Reverse
Reverse
| Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
- UINT
Duty
Control Type
Control Method
| Controls how the motor is controlled. On/Off requires basic output pins, motor is full speed or stopped. PWM requires a hardware PWM channel and allows the motor speed to be controlled. H-Bridge requires a hardware H-Bridge channel and allows the motor speed to be controlled.
Bridge Type
| Half Bridge - Motor can only be controlled in one direction. Full Bridge - Motor can be controlled in both directions.
Enable Method
| Decides how the motor outputs are enabled.
PinA
| First control pin - set 'pattern' properties below to set the pin's function.
PinB
| Second control pin - set 'pattern' properties below to set the pin's function.
Forwards Pattern
| The state of pins A and B required to drive the motor in a forwards direction.
Reverse Pattern
| States of pins A and B required to drive the motor in a reverse direction.
Coast Pattern
| States of pins A and B required to stop the motor.
Brake Pattern
Software PWM Settings
Timer
| Timer Peripheral to use to monitor the passage of time.
Prescaler
| Scaler applied to the timer, Small scalers allow for finer resolution but will limit the max time and also put more load on the microcontroller. Recommended to use as large a setting as possible which still provides enough accuracy.
Resolution
| Number of discrete values that the duty can have. e.g. 16 would allow duty values of 0-15 Recommend keeping this value low to avoid excessive amounts of interrupts.
Frequency (Hz)
| The frequency of the PWM output in Hz. Recommend keeping this low as possible to avoid having excessive amounts of interrupts.
Required Interrupt Rate (Hz)
| The calculated required rate of interrupts
Accuracy
| How close we can get to the required timings with the selected timer and prescaler
Off Time Setting
| Decides what to do when output PWM output is low.
Simulation Settings
Label Colour
Speed
| Speed of the motor when turned on. Positive speed -> Counter-clockwsie Negative speed -> Clockwise
Please click here to download the component source project: FC_Comp_Source_DCMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DCMotor_2d.fcfx
