Component: CAN (CAL) (Misc)
| Version | 2.4 |
| Category | Misc |
- 1 CAN component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckRx
- 5.2 GetList
- 5.3 GetRxData
- 5.4 GetRxDataCount
- 5.5 GetRxIdent
- 5.6 GetValue
- 5.7 Init
- 5.8 InitRXConfig
- 5.9 InitRXFilter
- 5.10 InitRXMask
- 5.11 InitTXBuffer
- 5.12 SendBuffer
- 5.13 SetRxFilter
- 5.14 SetRxFilterExd
- 5.15 SetRxFilterStd
- 5.16 SetRxMask
- 5.17 SetRxMaskExd
- 5.18 SetRxMaskStd
- 5.19 SetTxData
- 5.20 SetTxIdent
- 5.21 SetTxIdentExd
- 5.22 SetTxIdentStd
- 5.23 SetValue
- 5.24 Uninit
- 6 Property reference
CAN component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. Low level routines for controling the internal CAN peripheral.
Please click here to download the component source project: FC_Comp_Source_CAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CAN.fcfx
CheckRx
|   | CheckRx |
| Checks to see if any messages are available for 'Buffer' specified | |
|  - BYTE | Buffer |
| Send buffer: 0 to 1 | |
|  - BYTE | Return |
GetList
|   | GetList |
| Get the Filter List of the Named Property | |
|  - STRING | Name |
|  - STRING | Return |
GetRxData
|   | GetRxData |
| Returns the data byte at index from the buffer specified | |
|  - BYTE | buffer |
| The index of the required buffer | |
|  - BYTE | index |
| The index of the required data byte in the buffer | |
|  - BYTE | Return |
GetRxDataCount
|   | GetRxDataCount |
| Returns the number of valid data bytes in the buffer | |
|  - BYTE | buffer |
|  - BYTE | Return |
GetRxIdent
|   | GetRxIdent |
| Generic function to get the received message Identifier. | |
|  - BYTE | buffer |
|  - ULONG | Return |
GetValue
|   | GetValue |
| Get the Value of the Named property | |
|  - STRING | Name |
|  - STRING | Return |
Init
|   | Init |
| Must be called at least once and after every Uninit call to enable the CAN instance | |
|  - VOID | Return |
InitRXConfig
|   | InitRXConfig |
| Initialization setting for RX Buffer Config | |
|  - BYTE | Buffer |
| Buffer Number (0 or 1) | |
|  - BYTE | Value |
| Config data byte | |
|  - VOID | Return |
InitRXFilter
|   | InitRXFilter |
| Initialization setting for RX Filter | |
|  - BYTE | Filter |
|  - ULONG | Value |
|  - VOID | Return |
InitRXMask
|   | InitRXMask |
| Initialization setting for RX Mask | |
|  - BYTE | Mask |
| Mask Number (0 or 1) | |
|  - ULONG | Value |
|  - VOID | Return |
InitTXBuffer
SendBuffer
|   | SendBuffer |
| Sends the contents of the buffer previously filled with Set_TX_... calls | |
|  - BYTE | Buffer |
| Send buffer: 0 to,2 | |
|  - VOID | Return |
SetRxFilter
|   | SetRxFilter |
| Generic function to set Identifier. CAN registers will be configured depending upon Std/Ext mode setting. | |
|  - BYTE | filter |
|  - ULONG | id |
|  - VOID | Return |
SetRxFilterExd
SetRxFilterStd
SetRxMask
|   | SetRxMask |
|  - BYTE | mask |
|  - ULONG | id |
|  - VOID | Return |
SetRxMaskExd
SetRxMaskStd
SetTxData
SetTxIdent
|   | SetTxIdent |
|  - BYTE | buffer |
|  - ULONG | id |
|  - VOID | Return |
SetTxIdentExd
SetTxIdentStd
SetValue
|   | SetValue |
| Set the Value of the Named property | |
|  - STRING | Name |
|  - STRING | Value |
|  - VOID | Return |
Uninit
|   | Uninit |
| Uninitialises the CAN, freeing its connections for general use | |
|  - VOID | Return |
