| Author
Matrix Ltd
| Version
1.0
| Category
Graphical Color
GLCD (E-BLOCKS 3) component
Graphical display component designed to work with the E-Blocks 3 colour touchscreen display.
20, 20.0, 02-08-24, MW, Added an aditional font count of 4, total font count of 8
23, 23.0, 28-11-24, MW, Fixed error trap for lines when y = 0
23, 23.0, 28-11-24, MW, Fixed shapes colour background not working
23, 23.0, 29-11-24, MW, Fixed initial background colour not working
BPlot
BPlot
- UINT
X1
- UINT
Y1
BacklightBrightness
BacklightBrightness
| Adjusts the brightness of the backlight.
- BYTE
Brightness
| Range: 0 - 255, 0=Off, 255=Max
ClearDisplay
ClearDisplay
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- UINT
StartAngle
| Angle to start drawing, in degrees
- UINT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
| Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT
X0
| Start X coordinate
- UINT
Y0
| Start Y coordinate
- UINT
CX
| Control point X coordinate
- UINT
CY
| Control point Y coordinate
- UINT
X2
| End X coordinate
- UINT
Y2
| End Y coordinate
- UINT
Resolution
| Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawBitmap
DrawBitmap
| Draws a bitmap image loaded from the SD card FileInit must be called first to ensure the File System is setup.
- STRING
Filename
| Bitmap file to open from current directory on SD card 8.3 format
- UINT
X1
| X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT
Y1
| Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE
Orientation
| 0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE
Transparency
| 0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE
Flip
| 0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
- BYTE
DrawBitmapScaled
DrawBitmapScaled
| Draws a bitmap image loaded from the SD card scaled to the defined width and height. FileInit must be called first to ensure the File System is setup.
- STRING
Filename
- UINT
X1
- UINT
Y1
- UINT
Width
| The dimension to draw the bitmap in pixels
- UINT
Height
- BYTE
Orientation
- BYTE
Transparency
- BYTE
Flip
- BYTE
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawQRCode
DrawQRCode
- UINT
X1
- UINT
Y1
- BYTE
Scaler
| Size of each block in pixels: 1=33x33, 2=66x66, 3=99x99, etc
- STRING
Text
| Data to embed into the QR code. e.g. "www.myURL.com"
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
PrintFloat
PrintFloat
| This macro prints a floating point number to the Graphical LCD.
- FLOAT
Number
| Floating point number to send to the display.
- BYTE
NumDP
| Number of decimal points
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SendBinaryAction
SendBinaryAction
| Function to transfer the display manager edits through to the web mirror.
- STRING
Data
SendBinaryScene
SendBinaryScene
| Function to transfer the binary scene through to the web mirror.
- BYTE
Data
| Binary scene data
- UINT
Length
| Number of bytes to send
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
SetBitmapTransparency
| Assigns the colour to use as the transparent mask. Anything in this specific colour will not be drawn when the DrawBitmap->Transparent parameter is set.
- BYTE
R
| Colour channel. Range: 0 to 255
- BYTE
G
- BYTE
B
SetDisplayOrientation
- BYTE
Orientation
SetExternalFont
SetExternalFont
| This macro overrides the default font with a substitute font file. The binary font file must be placed onto the SD card inside the Fonts folder.
- BYTE
Font
| Selects which Font to override Range: 0 to (Font Count - 1)
- STRING
Str
| Binary font file to use in standard 8.3 file format
- BYTE
CharacterSpacing
| Number of pixel columns added in between each character
- BYTE
SpaceWidth
| Number of pixel columns used for a space character
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
TouchCheck
TouchCheck
| Checks to see if the screen has been touched. Returns 1 for a new valid touch and 0 for no touch.
- BOOL
TouchReadCoord
TouchReadCoord
- BYTE
Axis
| 0=X, 1=Y
- UINT
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Colour
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
EB3 Web Mirror
| Allows display manager scenes to be forwarded to a web parser that can replicate the on screen display and touch system. Allows the display to be monitored and controlled via a web enabled device like a mobile phone.
Fonts
Font Count
Font 0
Font
Font Filename
| Filename of font stored on SD card inside the Fonts folder
Bytes Required
| Number of bytes required in program memory to store the selected font.
Character Spacing
| Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
User Label Text
| Text to display
Component Label Scale
Physical Orientation
Bitmaps Folder
| Location containing the bitmaps for the simulation. $(scrdir) uses the Flowcode project directory.
Export Binary Fonts
| Allows all selected fonts to be exported as a binary format that can be loaded from an SD card. When set to yes loops through all selected fonts and outputs .bin files into the project directory. May take some time to complete, resets back to no when complete.
Please click here to download the component source project: FC_Comp_Source_GLCD_EB3_MatrixCapTouch.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_EB3_MatrixCapTouch.fcfx
