Author
Matrix Ltd.
Version
2.1
Category
Comms: System
Modbus TCP Slave component
Modbus component for creating Modbus compatible slave hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is initialised and connected to a network before calling the ModbusSlaveTCP component macros.
Please click here to download the component source project: FC_Comp_Source_ModbusSlaveTCP.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ModbusSlaveTCP.fcfx
Example master program to control the slave. The example sets coil address 0, clears coil address 0, reads an input register and outputs to the LCD. Be sure to set the IP address of the slave device at the top of the program. If you are simulating then use the IP address of the PC running the Slave simulation. Both programs can be simulated on the same PC using two instances of Flowcode.
Modbus TCP Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0 state to an LED connected to PortA. The input register is loaded with a value which is incremented on each Modbus transaction.
Modbus TCP Slave Example
Addressing
Data Type
Common name
Starting address
Ending Address
Flowcode Start Address
Flowcode End Address
Modbus Coils
Bits, binary values, flags
00001
10000
0
9999
Digital Inputs
Binary inputs
10001
30000
0
19999
Analog Inputs
Binary inputs
30001
40000
0
9999
Modbus Registers
Analog values, variables
40001
60000
0
19999
CheckForIncoming
CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
- BYTE
GetLastIncoming
GetLastIncoming
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
- BYTE
Index
Range: 0-3
- UINT
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
ReadAnalogInput
ReadAnalogInput
Reads the value of a single analogue input.
- UINT
Address
Coil Address
- UINT
ReadCoils
ReadCoils
Reads the state of a single digital coil. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
Range 1-8
- BYTE
ReadDigitalInputs
ReadDigitalInputs
Reads the state of a single digital input. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
ReadHoldingRegister
ReadHoldingRegister
Reads the value of a single holding register.
- UINT
Address
Coil Address
- UINT
SetAnalogInput
SetAnalogInput
Sets the state of a single analogue input.
- UINT
Address
Coil Address
- UINT
Value
Analogue Value range 0 - 65535
SetCoil
SetCoil
Sets the state of a single digital coil.
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetDigitalInput
SetDigitalInput
Sets the state of a single digital input.
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetHoldingRegister
SetHoldingRegister
Sets the state of a single holding register.
- UINT
Address
Coil Address
- UINT
Value
SetSlaveAddress
SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT
SlaveAddress
Modbus TCP/IP Properties
LinkTo
Status
Shows the state of the network comms component to verify everything is configured correctly.
TCP/IP Port
Port used for network communications Range: 0-65535
Receive Buffer Size
Receive Timeout
Maximum time to wait for reply, in mS
Slave Address
Address of the slave. Range: 0-255
Maintain Stats
Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Open and Close Socket
Simulation Properties
Modbus Coils - Single bit values
Starting Address
Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Digital Inputs - Single bit values
Starting Address
Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Analog Inputs - 16-bit values
Starting Address
Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Holding Registers - 16-bit values
Starting Address
Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
