Component: Isolated Input (BL0121) (E-blocks 2)
| Version | 8.8 |
| Category | E-blocks 2 |
Isolated Input component
A set of 2 isolated inputs that can take a high voltage or floating input and convert to a standard digital input via the use of opto isolators. A high is received when the voltage across the terminals is low 0 - 4V. A low is received when the voltage across the terminals is high 6 - 48V.
Version information
Library Version, Component Version, Date, Author, Info 8, 8.0, 02-04-25, MW, ESP32 compile fail. Added .Retun to ReadState function 9, 8.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise
ReadAll
| ReadAll | |
| Reads all of the inputs at once, returning a byte containing one bit per input. Range 0-3. | |
ReadState
| ReadState | |
| Read the state of the input at the given index. 0 = Voltage Present on input, 1 = No Voltage Present on input | |
| Index | |
| The input to read the status of. 0 or 1 | |
WaitUntilHigh
| WaitUntilHigh | |
| Pause the program until the input at the given index is turned on. | |
| Index | |
| Index of the switch to wait for. | |
WaitUntilLow
| WaitUntilLow | |
| Pause the program until the input at the given index is turned off. | |
| Index | |
Please click here to download the component source project: FC_Comp_Source_EB_IsolatedInput_BL0121.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_IsolatedInput_BL0121.fcfx
