Component: API (ECIO28P) (API Slave Devices)
Author | Matrix TSL |
Version | 2.0 |
Category | API Slave Devices |
- 1 API (ECIO28P) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ADCSample10
- 5.2 ADCSample8
- 5.3 ADCSampleArray10
- 5.4 ADCSampleArray8
- 5.5 ADCSampleAverage10
- 5.6 ADCSampleAverage8
- 5.7 ADCSetPrechargeTime
- 5.8 ADCSetReferenceVoltage
- 5.9 I2CInitialise
- 5.10 I2CReceive
- 5.11 I2CRestart
- 5.12 I2CSend
- 5.13 I2CStart
- 5.14 I2CStop
- 5.15 I2CTransInit
- 5.16 I2CTransReceive
- 5.17 I2CTransSend
- 5.18 IOGetInputPin
- 5.19 IOSetOutputPin
- 5.20 Initialise
- 5.21 PWMDisable
- 5.22 PWMEnable
- 5.23 PWMSetDuty
- 5.24 PWMSetPrescaler
- 5.25 RegisterRead
- 5.26 RegisterWrite
- 5.27 SPIInitialise
- 5.28 SPIPrescaler
- 5.29 SPITransfer
- 5.30 SPITransferTrans
- 5.31 UARTBaud
- 5.32 UARTCheckRX
- 5.33 UARTInitialise
- 5.34 UARTReceive
- 5.35 UARTSend
- 6 Property reference
Connects to an ECIO28P running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ECIO28P_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ECIO28P_API_Comp.fcfx
The App Developer (ECIO28P) component allows an ECIO28P board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ECIO28P hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ECIO28P App Developer Firmware
The COM port to the ECIO hardware is selected via the SCADA_ECIO28P component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 |
Device Port Pin | A0 | A1 | A2 | A3 | A4 | A5 | B0 | B1 | B2 | B3 | B4 | B5 | B6 | B7 | C0 | C1 | C2 | C6 | C7 |
App Developer Slave Analogue Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Device Port Pin | A0 | A1 | A2 | A3 | A5 | B2 | B3 | B1 | B4 | B0 |
App Developer Slave Peripheral Pin | I2C SDA | I2C SCL | SPI MOSI | SPI MISO | SPI SCK | UART RX | UART TX | PWM 0 | PWM 1 |
Device Port Pin | B0 | B1 | C7 | B0 | B1 | C7 | C6 | C2 | C1 |
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5 (the LED pin).
ADCSample10
ADCSample10 | |
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
- BYTE | ADCChannel |
Range: 0-12 | |
- UINT | Return |
ADCSample8
ADCSample8 | |
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255 | |
Range: 0-12 | |
- BYTE | Return |
ADCSampleArray10
ADCSampleArray8
ADCSampleAverage10
ADCSampleAverage8
ADCSetPrechargeTime
ADCSetReferenceVoltage | |
Specified the reference setting for ADC reads. | |
- BYTE | RefType |
0=AREF, 1=VCC, 3=Internal 1.1V | |
- VOID | Return |
I2CInitialise
I2CInitialise | |
Initialsie the I2C module ready for communications | |
- BYTE | Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
- BYTE | Baud |
0=100KHz, 1=400KHz, 2=1MHz | |
- VOID | Return |
I2CReceive
I2CReceive | |
Receive a byte using the I2C bus | |
- BYTE | Channel |
- BOOL | Last |
Last byte to receive: Range 0-1 | |
- BYTE | Return |
I2CRestart
I2CRestart | |
Put the I2C Module into Restart mode | |
- BYTE | Channel |
- VOID | Return |
I2CSend
I2CSend | |
Transmit a byte using the I2C bus | |
- BYTE | Channel |
- BYTE | DataOut |
- BOOL | Return |
I2CStart
I2CStart | |
Put the I2C Module into Start mode | |
- BYTE | Channel |
- VOID | Return |
I2CStop
I2CStop | |
Put the I2C Module into Stop mode | |
- BYTE | Channel |
- VOID | Return |
I2CTransInit
I2CTransReceive
I2CTransSend
IOGetInputPin
IOGetInputPin | |
Sets the selected digital pin to an input and reads the input state. | |
- BYTE | Pin |
Range: 0-18 | |
- BOOL | Return |
IOSetOutputPin
IOSetOutputPin | |
Sets the selected digital pin to an output and assigns the output state. | |
- BYTE | Pin |
Range: 0-18 | |
- BOOL | State |
Range: 0-1 | |
- VOID | Return |
Initialise | |
Initialise the comms to the Arduino board ready for commands to be sent. | |
- VOID | Return |
PWMDisable
PWMDisable | |
Disable a PWM output | |
- BYTE | Channel |
Range: 0-1 | |
- VOID | Return |
PWMEnable
PWMEnable | |
Enable a PWM output | |
- BYTE | Channel |
Range: 0-1 | |
- VOID | Return |
PWMSetDuty
PWMSetDuty | |
Sets the duty for the PWM output | |
- BYTE | Channel |
Range: 0-5 | |
- BYTE | Duty |
- VOID | Return |
PWMSetPrescaler
PWMSetPrescaler | |
Sets the prescaler for the PWM output | |
- BYTE | Channel |
- BYTE | Prescaler |
- BYTE | Period |
Default 255 | |
- VOID | Return |
RegisterRead
RegisterRead | |
Read one of the registers on-board the device | |
- UINT | RegisterAddress |
The address of the register | |
- BYTE | Return |
RegisterWrite
RegisterWrite | |
Writes to one of the registers on-board the device | |
- BYTE | Data |
The data value to assign to the register | |
- VOID | Return |
SPIInitialise
SPIInitialise | |
Initialsie the SPI module ready for communications | |
- BYTE | Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
- VOID | Return |
SPIPrescaler
SPIPrescaler | |
Modify the speed of the SPI bus | |
- BYTE | Channel |
Range: 0-2 | |
- VOID | Return |
SPITransfer
SPITransfer | |
Transfer a byte using the SPI bus | |
- BYTE | Channel |
- BYTE | DataOut |
- BYTE | Return |
SPITransferTrans
UARTBaud
UARTCheckRX
UARTCheckRX | |
Check to see if the UART module has received any data | |
- BYTE | Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
- BYTE | Return |
UARTInitialise
UARTInitialise | |
Initialise the UART module ready for communications | |
- BYTE | Channel |
- VOID | Return |
UARTReceive
UARTReceive | |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
- BYTE | Channel |
- BYTE | Return |
UARTSend
UARTSend | |
Send a byte via the UART module | |
- BYTE | Channel |
- BYTE | Data |
Data Byte to send. Range: 0-255 | |
- VOID | Return |
