Component: COM Port (Runtime Tools)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 3.0 |
Category | Runtime Tools |
- 1 COM Port component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ClosePort
- 5.2 ConfigureConsole
- 5.3 GetConsoleHandle
- 5.4 GetProp
- 5.5 OpenPort
- 5.6 ReceiveBinary16Bit
- 5.7 ReceiveBinary32Bit
- 5.8 ReceiveBinaryFloat
- 5.9 ReceiveByte
- 5.10 ReceiveByteArray
- 5.11 ReceiveFloat
- 5.12 ReceiveHexNumber
- 5.13 ReceiveINTArray
- 5.14 ReceiveNumber
- 5.15 ReceiveString
- 5.16 ScanForDeviceID
- 5.17 SendBinary16Bit
- 5.18 SendBinary32Bit
- 5.19 SendBinaryFloat
- 5.20 SendByte
- 5.21 SendByteArray
- 5.22 SendFloat
- 5.23 SendHexNumber
- 5.24 SendINTArray
- 5.25 SendNumber
- 5.26 SendString
- 5.27 SetDTRState
- 5.28 SetFlowControl
- 5.29 SetProp
- 6 Property reference
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
ClosePort
ClosePort | |
Closes the currently open COM port, ending communications and allowing it to be accessed via another application. | |
- VOID | Return |
ConfigureConsole
ConfigureConsole | |
- BYTE | Status |
- VOID | Return |
GetConsoleHandle
GetConsoleHandle | |
Gets the handle to the console allowing data displaying on the panel etc. | |
- HANDLE | Return |
GetProp
GetProp | |
Allows the property filter for the COM port list to be copied to a parent component. | |
- STRING | PropName |
- STRING | Return |
OpenPort
OpenPort | |
Opens the currently selected COM port, allowing data to be sent and received. | |
- VOID | Return |
ReceiveBinary16Bit
ReceiveBinary32Bit
ReceiveBinaryFloat
ReceiveByte
ReceiveByte | |
Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property. | |
- UINT | Timeout |
Time to wait for incoming data in milliseconds | |
- UINT | Return |
ReceiveByteArray
ReceiveFloat
ReceiveHexNumber
ReceiveINTArray
ReceiveNumber
ReceiveString
ScanForDeviceID
ScanForDeviceID | |
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found. | |
- STRING | HWID |
Example: "VID_12BF&PID_0101" | |
- BYTE | Return |
SendBinary16Bit
SendBinary16Bit | |
Sends out a 16-bit binary value split across two bytes. | |
- UINT | Value |
- BOOL | MSBfirst |
0=Least significant byte first, 1=Most significant byte first | |
- VOID | Return |
SendBinary32Bit
SendBinary32Bit | |
Sends out a 32-bit binary value split across four bytes. | |
- ULONG | Value |
- BOOL | MSBfirst |
- VOID | Return |
SendBinaryFloat
SendBinaryFloat | |
Sends out a 32-bit binary floating point value split across four bytes. | |
- FLOAT | Value |
- BOOL | MSBfirst |
- VOID | Return |
SendByte
SendByte | |
Sends a single byte to be sent out via the COM port. | |
- BYTE | Data |
- VOID | Return |
SendByteArray
SendByteArray | |
Sends an array of bytes to the COM port. | |
- BYTE | Data |
Data byte array to send | |
- UINT | Length |
Number of bytes to send | |
- VOID | Return |
SendFloat
SendFloat | |
Sends out a floating point number as an ASCII String from the UART interface. | |
- FLOAT | Number |
- VOID | Return |
SendHexNumber
SendINTArray
SendNumber
SendNumber | |
Sends out a number as an ASCII String from the UART interface. | |
- LONG | Number |
- VOID | Return |
SendString
SendString | |
Sends an string of characters to the COM port. | |
- STRING | Data |
- VOID | Return |
SetDTRState
SetDTRState | |
Allows the DTR signal to be enabled or disabled. | |
- BYTE | State |
A value of 0 disables the DTR, 1 or above willl enable the DTR. | |
- VOID | Return |
SetFlowControl
SetFlowControl | |
Allows the Flowcontrol signals to be enabled or disabled. | |
- BYTE | State |
A value of 0 disables flow control, 1 or above willl enable flow control. | |
- VOID | Return |
SetProp
SetProp | |
Allows the COM port property to be set from a parent component. | |
- ULONG | PropVal |
- VOID | Return |
