currently in the project explorer selecting a function and then listing occurrences brings up all the occurrences you have used.
right-click and remove all, only empties the list.
but I would like to remove all the occurrences I have made to that 1 particular function
A useful feature would be to have a remove all occurrences in the flow code itself and not just clear the list.
especially if you wanted to remove something that you had many of, instead of selecting each one manually
List occurrences, remove all feature
chloepowell4479
- Has thanked: 1 time
- Been thanked: 2 times
- Has thanked: 308 times
- Been thanked: 472 times
Re: List occurrences, remove all feature
Thanks for the good suggestion.
There is a workaround to do this currently as icon commands can be removed from the "disabled" icon list. Basically, first ensure no icons are disabled (i.e. make sure the "disabled" tab is empty), then select all results in the "find results" list, right-click them and select "disable". Finally, select all in the "disabled" list, right-click and select "delete".
It's not ideal and I will implement your idea in a future version, but the above workaround might be useful in the current version.
chloepowell4479
Thanks for the workaround
look forward to the future update
