Resizing Switch Arrays
Has thanked: 478 times
Been thanked: 713 times
Flowcode v10 Resizing Switch Arrays
Post by chipfryer27 »
When using the Switch Array (Slide) 2D, when resizing to say 6-positions, the text screws up a bit
Switch Arrays.JPG (52.27 KiB) Viewed 3177 times
Re: Resizing Switch Arrays
Following on from above, I was using latest FC on W8.1
I tried on my W10 machine running 10.0.0.14 and things were fine
Array Slide 2D FC10-0-0-14.jpg (77.13 KiB) Viewed 3154 times
I then updated the W10 to latest (inc libraries) and the problem returned.
Array Slide 2D FC10.0.1.18.jpg (76.59 KiB) Viewed 3154 times
EDIT...
As per advice another post earlier in the week, I deleted my FC10 folder on my W8.1 forcing FC to download latest, problem persists
Further to above, once closed and reopened I can't select the array unless I click outside the switch area and "drag" a rectangle across to capture.
Has thanked: 311 times
Been thanked: 479 times
Thanks. I've been able to replicate some of this and we're investigating.
Has thanked: 795 times
Been thanked: 858 times
Hi.
Would you like to try the attached components and see if they are better for you?
Just for anyone that does not know.
If you would like to try the component before the updates are pushed.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Replace the existing files with the attached files.
If you run any component updates, then the components you added will be overwritten
switch_array_push_2dgi.fcpx
(7.77 KiB) Downloaded 190 times
switch_array_slide_2dgi.fcpx
(7.38 KiB) Downloaded 182 times
Just tried on my W10 machine and all seems good.
Many thanks,
That's great!
Thanks for the update.
