Good afternoon!
How to configure MCP23017 macro to act as an input? I would like to connect 3 push buttons to port A GPA0-GPA1-GPA2.
MCP23017 INPUT
zoli2496
- Been thanked: 2 times
- Has thanked: 772 times
- Been thanked: 831 times
Re: MCP23017 INPUT
What version of Flowcode are you using?
When starting a new topic, we recommend using either a 9 or 10 post icon when the post is specific to a version of Flowcode.
- Has thanked: 634 times
- Been thanked: 842 times
Re: MCP23017 INPUT
Just call the read function with the appropriate port index and mask and the data direction will be done for you.
Re: MCP23017 INPUT
I use Flowcode v9. The output already works with the MCP23017, but the input does not. I want to use only certain inputs from the MCP ic, with a push button. If I press the button, the value of the corresponding variable should be 0 or 1. This is what I want to achieve.
I have attached pictures.
- SCHEMATIC.JPG (32.03 KiB) Viewed 5393 times
- MCP_IN.JPG (32.2 KiB) Viewed 5393 times
- DEBUG.JPG (34.52 KiB) Viewed 5393 times
Re: MCP23017 INPUT
more picture
- MCP_IN_CONFIG_3.JPG (35.81 KiB) Viewed 5393 times
- MCP_IN_CONFIG_2.JPG (37.2 KiB) Viewed 5393 times
- MCP_IN_CONFIG_1.JPG (35.56 KiB) Viewed 5393 times
Re: MCP23017 INPUT
Does reading the port work?
- MCP20317 port read demo.fcfx
- (9.54 KiB) Downloaded 704 times
- (view online)
Re: MCP23017 INPUT
Only "DF_PLAYER" works, "VOL_UP" and "VOL_DOWN" do not work. Also, the value of "VOL_DOWN" is constantly 1. (no button is pressed, the value of "VOL_DOWN" is still 1.) It does not respond to "VOL_UP".
- DUMA_CLOCK_PSA08_MCP_IN.fcfx
- (150.52 KiB) Downloaded 645 times
- (view online)
Re: MCP23017 INPUT
One thing I have noticed.
With you have got OR which is a bitwise OR operator.
Can you try with || which is a logical OR operator.
| is the pipe key which is usually on the same key as the backslash \
Have you measured the voltage directly on the MCP23017 input pins to check the hardware?
With
VOL_UP = 1 OR VOL_DOWN = 1Can you try with
VOL_UP = 1 || VOL_DOWN = 1| is the pipe key which is usually on the same key as the backslash \
