Yes - I have export.bat in c:\esp-idf
Your setup is at c:\users\45505\.espressif - I'm not sure if there has been discussion of not liking '.' in the path (or maybe it was ' ' (space) )
Full directory list:
Which version did you have installed - have you 'upgraded' to 5? (Which might not be a good idea yet?)
ILI9341 & XPT2046 Touchscreen
- Has thanked: 177 times
- Been thanked: 1022 times
jgu1
- Has thanked: 889 times
- Been thanked: 216 times
Re: ILI9341 & XPT2046 Touchscreen
Thank´s Martin
Meanwhile I have reinstall the ESP toolchain, no luck. The ESP-Idf ver. is 2.3 as recommended in the instalaltion instruction.
Every Lib. are placed as from start and I have compiled many time, but suddently today I could not more
The _ and the " is not used my fault when I wrote, sorry.
It´s so strange what suddently happen. hopefully Ben see this tomorrow, otherwice I have to report it in General or bug. My brain can´t hande more now
again I have used loooong time on troubleshooting.
Thank´s for your effort.
Br Jorgen
Br Jorgen
- Has thanked: 639 times
- Been thanked: 848 times
Hi Jorgen,
Yes I know the problem, It's me fixing a problem I've been having on Win 11 that another user had. Hmm not sure what to do now for the best.
viewtopic.php?f=3&t=1894
I'll roll them back for now so you can compile again.
jgu1
I download the two files and copy them to the ESP lib as you describe, but I still cannot compile in FC9 or FC10?
- LaptopOne.msg.txt
- (1.94 KiB) Downloaded 784 times
Sorry for the lack of sleep
I don't think this path looks to be correct?
ERROR: ESP toolchain not found at "C:\Users\45505\.espressif\"
In File -> Global Settings -> Locations tab, check you are pointing to the esp-idf installation folder.
jgu1
Hi Ben!
Ok, lack of sleep, are you working to much?
but you're still a little awake, it work now and I can compile on both laptop again with the correct path, thank,s
Is it dangerus in the nearest future to make an update, concerning the issue with Win11?
Have you seen mfishers answer I highjacked the history with my issues. I will test later.
Have a good sleep.
Br Jorgen
Have a good sleep.
Br Jorgen
- Skærmbillede 2023-04-24 203419.png (39.83 KiB) Viewed 10158 times
