Two TCP/IP Sockets
wayne_millard
Has thanked: 1 time
Been thanked: 9 times
Two TCP/IP Sockets
Post by wayne_millard »
Hi Team,
Is there a problem with using two TCP/IP sockets i wrote a project 1 year ago and it worked and no it dont.
Im using one socket to comunicate with a device and the second socket running Server/client.
Help would be good.
Thanks,
Wayne Millard
Has thanked: 306 times
Been thanked: 471 times
Re: Two TCP/IP Sockets
Do you have the C code output for the working project and the C code output for the non-working project? That could help us pinpoint the issue.
Another thing to look for is to ensure the pin connections are all correct as sometimes these are reset when opening an older project.
wayne_millard
Has thanked: 1 time
Hi team
Sorry for the misunderstanding it not hardware with two TCP/IP sockets. It's a problem with app developer.
I can't get both TCP/IP sockets to work at the same time in one app. They are on different channels 0,1.
Wayne M
Can you please give some more details - for example, Flowcode version (when it worked and when it did not).
