Hi!
I starting up a project where I want to use PWM. If I open the examble from Wiki I am able to see the timing pulse with. In Fc10 I only see a slider like potmeter and can´t see the pulsewith in simulation, is this normal? please.
Br Jorgen
PWM Internal!
jgu1
- Has thanked: 839 times
- Been thanked: 205 times
PWM Internal!
- PWM FC10.png (11.26 KiB) Viewed 2382 times
- PWM from Wiki.png (10.23 KiB) Viewed 2382 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: PWM Internal!
Hi Jorgen.
Yes, that is normal as that is the default.
If you want to have the lower image instead of the upper image then within the PWM properties, under Simulation, change Representation from Analogue to Digital.
I must admit I do like the digital.
But I'm a bit biased as I designed the digital version lol.
Any coments on the design are welcome, positive or negative.
jgu1
Re: PWM Internal!
Well Well Martin one more good thing in FC. I did not know it was possible. Yes I also prefer the old view.
Test it tomorrow. Thank you for fast reply and help.
Br jorgen
Br jorgen
