PIC32 USB CDC No function after last update
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
Re: PIC32 USB CDC No function after last update
Greetings SpeedPic32
- 13-09-2023 17-39-26.jpg (61.89 KiB) Viewed 10775 times
- 13-09-2023 17-37-00.jpg (62.11 KiB) Viewed 10775 times
SpeedPIC32
Hello together
When the driver is in place, Win 10, 7 and XP recognise it as a Flowcode USB Serial device. The driver is installed and then works normally.
At the moment I can compile in FC9 and 10 without errors but no operating system recognises the device. I get the message Unknown device and error when requesting a device description.
SpeedPIC32
Hello together
I have noticed
in FC 9 I can recompile software I wrote before the update and the USB port works.
i can change the software, compile it and usb works. if i write something new usb does not work.
it would be nice if someone would take care of this for once
greetings SeedPic32
I have noticed
greetings SeedPic32
- Has thanked: 311 times
- Been thanked: 479 times
Please post your working project (FCFX, C and driver files) and also a new project which does not work (again, FCFX, C and driver files) and we will try to discover the problem.
SpeedPIC32
Hello Steve
Here is my data from FC9
Where can I find the driver or the batch file?
- USBCDCTEST.fcfx
- (14.5 KiB) Downloaded 870 times
- (view online)
- USBCDCTEST.c
- (47.5 KiB) Downloaded 729 times
SpeedPIC32
here these do not work.
- USBCDCTESTneu.fcfx
- (8.49 KiB) Downloaded 822 times
- (view online)
- USBCDCTESTneu.c
- (42.59 KiB) Downloaded 932 times
SpeedPIC32
Replace txt with bat
- PIC32compCDC.txt
- (7.54 KiB) Downloaded 769 times
SpeedPIC32
$(compilerpic32)batch\PIC32compCDC.bat
"$(chip)" "$(srcdir)" "$(target)" "$(family)"
Thanks for the files.
I've compared both files and these are the differences between the 2 projects:
- Config settings for the chip are very different
- The old one uses a delay which clears the watchdog automatically
SpeedPIC32
Hello all
Steve Matrix was right.
It just didn't work with the alignment of the data anyway.
Now I had a good idea.
I took over the compiler options from version FC9 and now it works again.
Here is my data
Compiler location
Parameter
Linker / assembler location
$(compilerpic32)bin\xc32-bin2hex.exe
Parameter
"$(srcdir)$(target).elf"
Programmer location
$(mplabxdir)mplab_platform\mplab_ipe\ipecmd.exe
Parameters
/P$(chip) /F"$(outdir)$(target).hex" /TPPK4 /M /OL
File Viewer Location
C:\Windows\Notepad.exe
Parameters
$(outdir)$(target).c
I hope it helps one or the other.
SpeedPic32
Here is my data
Compiler location
Parameter
Parameter
Programmer location
Parameters
Parameters
SpeedPic32
