problems with component: csv Read/write --> ReadAsNumber
Mcolin
Flowcode v10 problems with component: csv Read/write --> ReadAsNumber
Post by Mcolin »
Hello everyone.
I started using the Component:
CSV Read/Write
using the macro:
ReadAsNumber
using csv file:
when I try to read the cell with the position row: 1 column:1.
It never works to read a position other than row:0 column:0.
The simulation never ends and does not display any value on the display.
assuming that if the value for row:0 column:0 was obtained, the connections and components are correct.
please help.
WingNut
Has thanked: 56 times
Been thanked: 43 times
Re: problems with component: csv Read/write --> ReadAsNumber
Post by WingNut »
If you post your flowcode file the guys will have a better chance of figuring out the problem
Mcolin
Post by Mcolin »
main csvr ead/write.fcfx file
2 diferent csv files to test
main csv_read_write.zip
(6.79 KiB) Downloaded 601 times
dont forget to change files folder root directory
ready to download and run
thanks.
Has thanked: 642 times
Been thanked: 850 times
Many thanks for letting us know, hopefully fixed for you now via the library updates.
