ESP32 & ENC28J60
Frco007
Has thanked: 3 times
Been thanked: 1 time
Flowcode v10 ESP32 & ENC28J60
Post by Frco007 »
Can anyone help me what am I doing wrong?
The compiler reports an error...
Br
ESP32_Server_LAN.fcfx
(25.2 KiB) Downloaded 640 times
Has thanked: 725 times
Been thanked: 784 times
Re: ESP32 & ENC28J60
I have moved this to bugs as it's nothing you have done wrong.
Thank you for bringing this to our attention
Hi.
Ben has updated the component, so it should now be available when you select Help > Library Updates...
Frco007
Post by Frco007 »
Hi.
I just compiled the program and it only works when I RUN it with debug.
Can you please check where the error is? PING does not work and if I send the string "P21" (TCP) to IP 192.168.1.90, PORT 555, it returns Could not connect. Are mask and GW settings not necessary by ENC28J60? These settings exist for the W5500 LAN interface.
After I upgrading ESP32 WROOM to V9 (Library Updates), the compiler does not work again. When I revert ESP\ESP32_WROOM_32.fcdx to V8 the compiler works.
I would like to ask if you can check where the problem is that the program works for me in debug mode, but physically the module ENC28J60 does not work when I compile the program (with V8).
Best regards,
Has thanked: 444 times
Been thanked: 669 times
Post by chipfryer27 »
Can you post your current chart as I am a bit confused. The one you posted earlier has an IP of 192.168.100.90 a MAC of 0-0-200-10-0-0 and is running on Port 80 (which is a generic browser port, HTTP).
It has been years since I last used one of the modules but as far as I am aware (and I could very well be wrong) the module operates at Data Link layer (layer 2) so only communicates using MAC addresses. Unless you have further code / libraries etc to handle the higher layers then you won't get too far trying to use TCP/IP.
Frco007
Flowcode v10 Re: ESP32 & ENC28J60
Post by Frco007 »
Last chart which I used is in attach file.
ESP32_Server_INPUT_LAN_NOVO.fcfx
(28.15 KiB) Downloaded 717 times
There is an example of using the module as a server on the WiKi
https://www.flowcode.co.uk/wiki/index.p ... etworking)
It might throw some light?
