FC10 Hardware I2C on MCP23017 not working
pschoon
Been thanked: 3 times
Post by pschoon »
Developed a small PIC16F18877 control board with MC23017 IO expander on it.
I2C to expander is working in software mode but not in hardware mode (channel 1)!
IO_Switch_V100.fcfx
(25.49 KiB) Downloaded 440 times
Has thanked: 786 times
Been thanked: 844 times
Re: FC10 Hardware I2C on MCP23017 not working
Thank you for the bug report.
I will be looking into this as soon as I can.
The issue is caused by forcing the I2C pins low your expander is connected to.
It is a bad idea to force I2C high or low.
What you need to do is select Advance options of both outputs to port C and select:
Output to: Single Bit: 0
As this is not an I2C bug I have moved the topic to a more suitable location.
