CSV writer (overwrite row data)
RGV250
Has thanked: 46 times
Been thanked: 45 times
Post by RGV250 »
This is probably a very simple thing but I cannot figure out how to do it. I have created a test file to simulate data, I can create a CSV file and increment the rows and all is fine. I then tried to overwrite the same row but it just adds the new data to the next column on the same row.
Is it possible to do this.
I have attached the test file and the CSV file it creates
CSVTestRPI_1.fcfx
(12.13 KiB) Downloaded 857 times
test1.csv
(1.08 KiB) Downloaded 897 times
Bob
RGV250
Re: CSV writer (overwrite row data)
Post by RGV250 »
I did have a thought if this is not possible with the current commands if I could modify the "Next row" but that only seems possible with the professional version. Is it possible to view the code so I can create my own component or is this only possible in the professional version as well.
If it is possible can you let me know where the information is. I did find this
https://www.flowcode.co.uk/wiki/index.ph ... _Component
but that is for an old version and also seems to only be for the professional version.
Bob
Has thanked: 704 times
Been thanked: 768 times
One of the new features of v10, we have allowed most of the components to be open source.
You can download or view the source code, by selecting the component on the panel, right-click and select help.
Or you can right-click help from Component Libraries or component search.
You will need to change the GUID, otherwise when you do an update, your component will be overridden.
I mentioned how to do that in this post.
You should be able to do that with pro or non pro license.
Component creation can be found on the v10 Wiki
Has thanked: 593 times
Been thanked: 780 times
Updating a value in a CSV is tricky, mainly as it means manipulating a file half way through. Inserting or deleting characters needs to be rippled through and written to all the sectors of the file and so it's not a trivial task.
One way is to read the contents of the file into memory and then open the file again, erasing the contents and re-writing the file with the new updated data. This will work for smaller files and is a trick I have used before.
I'll have a think and see if we can find a nice way to edit half way through a file in a way where all the complexity is taken care of for you, this should make overwriting a cell a lot easier.
Has thanked: 156 times
Been thanked: 909 times
Post by mnfisher »
One idea is to use fixed length data - say four hex digits - then a particular sample is always at a fixed position - this saves changing the file size if data is overwritten.
LeighM
Has thanked: 98 times
Been thanked: 294 times
Post by LeighM »
... a trick used by the IBM AS/400 :lol:
RGV250
Post by RGV250 »
This may not be neccessary now, it was the only way (that I understood) that I could see of getting data from FC into a database.
Chipfryer has been doing a lot of work trying to help me with PHP GET function which seems to be a nice solution.
Bob
