HC05 Bluetooth: send command and set pair key macro problem!!!
Mcolin
Post by Mcolin »
*send command macro
and
*set pair key macro
don't works.
here you have an example of at command structure to verify the correct syntax:
ejemplo at comand.gif (2.86 MiB) Viewed 3371 times
correct syntax is not possible to add.
AT COMAND PROBLEM.png (165.29 KiB) Viewed 3371 times
Mcolin
Re: HC05 Bluetooth: send command and set pair key macro problem!!!
Post by Mcolin »
command to change name works!! so, the communication between micro controller an Bluetooth module its OK!!
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
If you need to send quotes within a string you can use a backslash to escape it,
So your correct command translates to “AT+PSWD=\”6789\”” in the expression box.
