file attached.
I will check out the toolchain issue
License Activation
pmaud
- Has thanked: 724 times
- Been thanked: 783 times
Re: License Activation
I'm not sure what your issue is as your .txt.msg states:
So, your hardware has been programmed.
Have you got your hardware wired up correctly?
Perhaps check D3 with a scope, DMM or logic analyser.
Programming successful!Have you got your hardware wired up correctly?
I did the AVR download from the FC page. I took the option to "Repair" and it ran and finished.
How do I verify that it is now in place?
In other words which folder does it sit in?
I notice that there are 2 main folders one is Flowcode and has a folder inside called Common.
The other is called Flowcode v10 with 14 folders and 2 files.
Is this a "normal" installation? If not should I reinstall everything?
