Is there a lot of difference between the 18f47q43 and the 18f47q84 compiler wise? I have a few of the Q84's.
When do you think the newer xc8 compiler will be employed?
Modbus TCP Slave
WingNut
- Has thanked: 50 times
- Been thanked: 37 times
- Has thanked: 592 times
- Been thanked: 780 times
Re: Modbus TCP Slave
I've replicated the problem and am working on a fix for you.
I tested it on MCUs of PIC18F45K40, PIC18F67K40, PIC24FJ512GA606. But it doesn't work at all.
Please let me know any alternative method. I will test it using the method you provided.
Please.
Thank you.
Please.
Thank you.
Please tell me which MCU (PIC 8-bit or 16-bit) works well and I will change the PCB design to that.
If you give us a working sample program, I will modify the project to fit it.
Please help me.
thank you.
Please help me.
thank you.
Looks like the bug is in the library somewhere. Looking into it again for you today.
