WS2812 Build Error ( STM32F407ZG )
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Post by Alan_37 »
Here is a Simple fcfx file I made just to show the bug, this compiles ok on V7 but not on V9 maybe we can fix this .
Flowcode1.msg.txt
(84.57 KiB) Downloaded 924 times
Flowcode1.fcfx
(9.64 KiB) Downloaded 815 times
Has thanked: 616 times
Been thanked: 814 times
Re: WS2812 Build Error ( STM32F407ZG )
Thanks for letting us know, hopefully should be fixed for you now.
Alan_37
Post by Alan_37 »
Thanks for your reply update done and now compiles Perfectly.
Sundgau
Post by Sundgau »
I am happy to read that the compilation is done correctly but my question is: is the led lighting correctly?
As quoted in the FlowcodeV7 forum: https://www.flowcode.co.uk/mmforums/view ... 76&t=22045
With an ECIO40 and an ECIO40P16, compilation is performed without warning.
With a 16F887A clocked at 19.6608MHz, the same warning reappears :
#warning WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed
^ (162) #warning: WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed (warning)
With these 3 targets, the high and low state times for the two logic states do not comply with the WS2812B protocol and the Led lights up in white.
Is it a problem of frequency of work?
Bruno
Alan_37
Post by Alan_37 »
Hi , on V9 it is compiling and working ok , though I once notice that yes at first it lights up white then after the second refresh it starts to work correctly , could be that there are still bugs
Sundgau
Post by Sundgau »
Thank to you Alan,
Did you check the timing on the command output with multiple leds in cascade or a RGB LED strip? I am curious to know the result if you have the material ...
Bruno
Alan_37
Post by Alan_37 »
On V9 this seems to be fixed but I think on V7 & 8 still present
I beleive should be fixed in v8 now. Do you need it for v7 also?
