Hi Matrix Dev,
I checked, when sending a message via mqtt publish, there is a limit on the number of characters that can be sent. What is the maximum number of characters that can be sent at one time? Can you add variables to the properties to be able to change them?
Thank you
sandinug
Change max character can send by mqtt Publish
sandinugraha
- Has thanked: 4 times
- Been thanked: 2 times
- Has thanked: 639 times
- Been thanked: 849 times
Re: Change max character can send by mqtt Publish
Many thanks for the suggestion, I've added this into the component for you now.
sandinugraha
Hello BenR,
Great, with this capability, sending mqtt publish messages will be more numerous and can be adjusted to suit your needs.
Thank you very much for the support
sandinug
sandinug
sandinugraha
Today i just received update for mqtt client, and yes i see new Max Packet Size Variable has been added to the properties.
but when i do compile, there is just error, i also try this with example mqtt component and the error is arrise too. even i didn't change value for that variable.
Sandinug
Sandinug
- SubscribeESP32.fcfx
- (16.56 KiB) Downloaded 540 times
- (view online)
sandinugraha
Any update for this bugs ?
Thank you
Sandinug
Thank you
Sandinug
- build error mqtt client.png (300.78 KiB) Viewed 9095 times
Sorry for the delay, hopefully resolved for you now.
