A serious problem:ServoMotor is not working properly
17712885438
V10 compilation HEX file is all right. But downloading it to the chip is not right. But downloading everything in V8 is ok. I tried PIC series, arduino series. V10 does not work properly after downloading.Attach example
17712885438
help me
Servo motor is not working properly when the hex file is loaded into proteus, and theServo motor does not turn when the hex file downloaded into the chip. But in V8 it all works fine. Please help me.
- Has thanked: 702 times
- Been thanked: 768 times
Re: A serious problem:ServoMotor is not working properly
Hello, sorry for the delay in replying.
There is a bug with the latest servo.
To get the servo working again, you will need to rollback from v7 to v6.
Instructions can be found within the Wiki here.
I have fixed the servo controller.
There are additional functions now which are MoveToAngle & AutoMoveToAngle
To try the Servo Controller out, before it's push onto the database:
Place the attached component.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- Servo_Controller.fcpx
- (19.3 KiB) Downloaded 103 times
I can confirm, a working servo controller component has been pushed onto the component database.
This includes the two extra functions.
