ESP32 GPS UART not working!
jgu1
Has thanked: 871 times
Been thanked: 212 times
Post by jgu1 »
Hi!
I think I have found a bug in the ESP32 :(
In a project I discorverd that the Uart not working. I have connect a GPS but get no data from it.
I create a small testprogram where I try to receive the second´s from GPS time. Not worikng with ESP32.
Then I create the same testprogram with an Arduino, work fine. (but the Arduino is not as fast as ESP with ILI9341 display :| ).
Br Jorgen
ESP32 ILI9341 GPS.fcfx
(15.19 KiB) Downloaded 622 times
jgu1
Re: ESP32 GPS UART not working!
Post by jgu1 »
Hi!
I dare to ask, is it just like that and is the solution to find another device for the purpose, please :roll:
Br jorgen
Has thanked: 245 times
Been thanked: 256 times
Hi Jorgen
Can you check your program if you read sekund and display speed?
And which pin did you use from the ESP32?
jgu1
Post by jgu1 »
Hi Stefan!
Thank´s for reply. Yes you have rigth concerning the Speed and second. I have change it so the return now is Second ;)
But it still not work. I have tested all the Uart input.
Channel 1 = RX0 pin A3
Channel 2 = RX1 pin A16
Channel 3 = ?
I try to swap input, use other pin, yes almost everything no luck. As I mentoied, if I test on Arduino I see the second´s. I also test with a Scope and I see data out of the GPS.
The display show 0
Have you any experience with the Uart on ESP32?
Thank´s in advance.
Jorgen
(15.17 KiB) Downloaded 745 times
Has thanked: 757 times
Been thanked: 819 times
Hi, Jorgen.
I'm currently using an ESP32 Lolin to receive data from a PZEM-004T via Modbus and I have the ESP32 sending the data via UART to Tera term:
I'm assuming as the Modbus is working then I/P and O/P of UART is working.
Plus I have an additional UART output working.
So rather than FC UART component, could be a FC GPS component issue?
Hmm trouble with LED lamps, crap power factor with capacitor droppers lol.
LeighM
Has thanked: 107 times
Been thanked: 302 times
Post by LeighM »
Yes, I've confirmed that it is.
Investigating now ...
jgu1
Post by jgu1 »
Hi Martin and Leigh!
Thank you.
Ok, and yes, if martin can receive data on Uart, it may work.
But, strange for me. when I use the same GPS on Arduino it work fine. When I test with ociloscoope I see data from the GPS. but nothing on display.
The GPS is : https://www.ebay.com/itm/GY-NEO-6M-V2-m ... Sw6Fteb61w
I supply it with 3,3V from the ESP.
Please advice.
Br Jorgen
LeighM
Post by LeighM »
I've done some changes to ESP CAL UART code to support the GPS component when used with ESP.
Might be a while before the update is on the auto-update system,
so if you want to try, copy the attached file to
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP
ESP_CAL_UART.c
(19.48 KiB) Downloaded 650 times
jgu1
Post by jgu1 »
Ok Leigh! I try later today or tomorrow. You hear. thank´s
Jorgen
jgu1
Post by jgu1 »
Hi LEigh!
Sadly, no change. Is there anything I could test/try or do,please?
Jorgen
