DirkB
Posts: 118 http://meble-kuchenne.info.pl
Has thanked: 1 time
Been thanked: 4 times
Post
by DirkB » Fri Feb 06, 2026 9:35 am
I ported a project from PIC16F1825 to PIC16F18426. PIC16F18426 does not have MIDI component and DAC component functions. If I create a project with only these two components, I get an error message.
new project:
https://www.flowcode.co.uk
Error creating C source code:
test-18426.c : 208 : error : Syntax error
Autoclose turned off
TERMINATED
portet project:
E:\Flowcode\V10\2025\Bambledrive\Final>"C:\Program Files\Microchip\xc8\v2.50\bin\xc8-cc.exe" -mcpu=16F18426 "Bambledrive-16F18426-V.2.5.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_DAC.c:298:1: error: (192) undefined identifier "DACCON0"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_DAC.c:311:1: error: (192) undefined identifier "DACCON1"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_DAC.c:317:1: error: (192) undefined identifier "DACCON0"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_UART.c:590:1: error: (192) undefined identifier "RX1DTPPS"
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\batch\pic_xc8_comp.bat Hat den Fehlercode 0x1 gemeldet
TERMINATED
Posts: 2289 Joined: Mon Dec 07, 2020 10:06 am
Has thanked: 634 times
Been thanked: 840 times
Post
by BenR » Fri Feb 06, 2026 12:39 pm
Hello Dirk,
Thanks for letting us know, investigating for you now.
Post
by BenR » Fri Feb 06, 2026 12:50 pm
This should be fully resolved for you now in both v10 and v11.
Simply go to Help -> Library Updates to get the latest definition files.
Let us know if you come across any further issues.
DirkB
Posts: 118 Joined: Thu Dec 10, 2020 3:55 pm
Has thanked: 1 time
Post
by DirkB » Fri Feb 06, 2026 1:22 pm
The ported project now compiles without errors, thank you for that. Here is a very small program. It runs without errors in the simulation, but produces an error message during compilation. What have I overlooked?
thank you
test-18426.fcfx
(13.1 KiB) Downloaded 366 times
Post
by BenR » Fri Feb 06, 2026 4:45 pm
Hello Dirk,
Great glad that solved the problem for you.
In your MIDI component properties there is no RX remap pin assigned which is causing your compilation error.
DirkB
Has thanked: 1 time
Post
by DirkB » Wed Feb 11, 2026 5:18 pm
grrrh!!!
thanks ;o)
