UART ports
Abhijit
Has thanked: 15 times
UART ports
Post by Abhijit »
Hello!
Did someone ever come across any 8bit chip of PIC having 3 UART ports, or it is always 2 ports only and for 3 or more ports i need to shift to 16bit chips. If the option is 16bit kindly point out a couple of basic chips available easily and in FC10 too.
Thank you.
Abhi
Has thanked: 469 times
Been thanked: 697 times
Re: UART ports
Post by chipfryer27 »
Microchip has a part selector tool that you can use to specify your needs
https://www.microchip.com/en-us/paramet ... IlNUQlN0Q=
As far as I am aware two is the maximum 8-bit PICs have, but you might be able to also use a Software Channel?
Has thanked: 759 times
Been thanked: 825 times
Re: UART ports
If you select Embedded > Target Selector, that will display all the target devices Flowcode supports.
You can then Select PIC 8bit, then change the Show 25 devices to 100.
Finally click the Arrow to the right of UART, so it shows pointing down.
You will then see the total supported UARTS:
Total UARTs.png (168.82 KiB) Viewed 3900 times
Re: UART ports
Hi Martin
That's interesting that FC shows those devices. When I looked on the Microchip site I didn't find any and filters only allowed me to select two ports. Entering the chip above it returned 0-ports... FC wins again :)
Re: UART ports
Hi Iain
I agree, the parametric search tool is not great for UARTS.
Just as reminder for Flowcode targets which allow filtering there is my spreadsheet found here.
Re: UART ports
Hi Martin
I'd forgotten about your spreadsheet (which in the past I found very useful) probably due to changing laptops and not yet transferring everything over. For those using PICs it's worth downloading.
Abhijit
Re: UART ports
Post by Abhijit »
Hello! Iain and Martin
Good morning
Many thanks for pointing out the links, yes indeed the target selection helped me to identify the chip I wanted, and found one with 4 UART, and the best part is I can use that for free, thank you to FC.
Thank you again to both of you.
Abhi
