Steve,
do you have an explanation as to why these files were modified?
Compile problem with FC11
B2CAP-V6
- Been thanked: 7 times
- Has thanked: 308 times
- Been thanked: 472 times
Re: Compile problem with FC11
Great news. I have no explanation as to why they were modified. Flowcode does not change them, except to replace with new versions via Library Update.
Steve,
I just realized the .cof file is missing.
This file is very important for debugging in Proteus.
All these problems are really strange.
I uninstalled and reinstalled PIC 8-bit toolchain, and it's the same; I still don't have the file with the .cof extension.
There will be a .elf file which serves the same function as a .cof file. I assume that Proteus has an option to use .elf instead of .cof. But if not, there may be a way to force the toolchain to output a .cof file instead (or as well).
Thanks Steve for your feedback.
It's not possible to load program files other than .hex, .d39, .bas, and .cof. on Proteus
Furthermore, I installed FC 11 on another computer and I do have the .cof extension. I also had it before this series of problems, and I also had it on all FC 6, 7, 8, 9, and 11. I don't understand what happened.
- Has thanked: 177 times
- Been thanked: 1022 times
It looks like support for .cof has been removed from later versions (>2.0) of xc8.
On my machine - it (xc8) generates only .elf files.
I attempted to 'coerce' the compiler/linker to revert to .cof by altering the command line used to include
-std=c90 and -output=cof
- which wasn't successful
So - I would suggest either installing an older version of xc8 (copy from a machine where it works?)
Or - is there a newer version of Proteus that supports elf files?
Thanks Martin for your feedback.
Regarding Proteus, I have the latest version, 9.1 SP4.
Now I downloaded it from my other computer (XP8 v1.45) and changed the compiler path. I received error messages during compilation. I uninstalled FC11 and reinstalled it. I also uninstalled the Picv2 toolchain and installed the v8_Flowcode Compiler (which I should have on the other computer). Now I can no longer compile. FC11 was probably uninstalled incorrectly.
- Capture d’écran 2026-03-03 102335.jpg (53.31 KiB) Viewed 4956 times
I've not tried it, but -gcoff might generate a .cof file when used as a command line switch for xc8.
I can now compile after a complete uninstall of FC11. But I still have the same problem: I don't have the file with the .cof extension.
