RPI 4B Flashing LED Test Compile Fail
canary_wharfe
Has thanked: 10 times
Been thanked: 14 times
Post by canary_wharfe »
Just purchased the RPI/PICO component bundle and did a quick LED flash test using the RPI 4B.
Simulation is fine. Build to HEX compile fails immediately.
RPI_CAL_String.c fail
Don't think the problem is my toolchain. Could someone quickly check.
All the files are attached in the zip.
Charles
RPI 4B Flashing LED Test Compile File.zip
(5.55 KiB) Downloaded 25 times
LeighM
Has thanked: 99 times
Been thanked: 299 times
Re: RPI 4B Flashing LED Test Compile Fail
Post by LeighM »
I've not had chance to check your zip yet.
But have you tried a full database update?
The CAL string files have had some changes recently.
canary_wharfe
Yes I just did a full update and the compilation error is still there unfortunately.
LeighM
Post by LeighM »
Looks like RPI_CAL_String.c is missing the FCLsz_TEMPSTR fix and other updates - one for Ben :D
Has thanked: 599 times
Been thanked: 794 times
Hopefully fixed for you now.
Thanks for letting us know.
canary_wharfe
Yes, all working now. Thanks Ben.
