I can't compile the program. I found that if I remove the timer component the program compiles.
Kind regards
Esp32 Timer Problem
Oscar_T
- Has thanked: 37 times
- Been thanked: 10 times
LeighM
- Has thanked: 107 times
- Been thanked: 302 times
Re: Esp32 Timer Problem
Looks like the Timer component is not yet compatible with ESP.
Can I suggest that you use a Timer Interrupt instead.
That can then call a macro/function that increments global variables to give you your timed events.
Oscar_T
Thanks Leigh
Now i've another question
I am trying to use the esp32 module to create a small test station. I need to generate a sine wave and I succeeded.
the problem is that the output is not stable and therefore every few seconds I find a glitch on the sinus. I tried to generate the wave in different ways but even putting it in the main loop I always have the same problem.
It almost seems that the output of the dac stops ...
LeighM
I think the problem here could be that ESP runs an RTOS.
That's not ideal for signal generation due to task scheduling.
I think that DMA might be possible, but I've not tried it.
- Has thanked: 634 times
- Been thanked: 838 times
What are you using the output the sine wave, is it the internal DAC or PWM or is it via an external comms device?
Oscar_T
I have a strange problem with esp32 boards.
It looks like they are programmed but fail to boot ...
I have 3 boards (1 wroom-32 and 2 wroom-32d) and all three are doing the same joke
The version is esp32_devkitc_v4, clicking the two physical buttons nothing happens.
