ESP32 Wlan connect, but how to read IP Adress
Has thanked: 246 times
Been thanked: 258 times
To connect the ESP Wlan to my own wlan is working with connectToSSID , but how to read IP Adress with the command ReadIP?
it give just a Byte return.
it would also be possible to add a set command (WriteIP) in the future?
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Re: ESP32 Wlan connect, but how to read IP Adress
Post by Alan_37 »
Hi ,
I think you have to read a byte at a time incrementing the index value but don't really know
how you would know where to put the point you will end up something like this 19216801 for 192.168.0.1
LeighM
Has thanked: 110 times
Been thanked: 302 times
Post by LeighM »
Yes, you can use ReadIP to populate a byte array.
Then use string conversion to get into human-readable notation ...
Hi Alan, Hi Leigh
Perfect! Thank you both. It's working this way.
