HI ,
I'm trying to control my power supply's trough tcp/ip
I worked it out to control 1 power supply .That program works great . but when I'm trying to connected the other one it all goes wrong .
what i tryed so far:
-every powersuply has it's unique ip adress and its on port .
-do i have to close the port every time i connect to another power supply?
I'm totally new in al the internet things
thanks in advantage for your help guys .
how to connect to different node's trough tcp ip
ruben123
- Has thanked: 6 times
- Been thanked: 3 times
- power_suply_V_A_P_with_feedback_minderbelasting_TCPIP_keymapping_test_belasting1V2.fcsx
- 2power supply's
- (58.35 KiB) Downloaded 820 times
- (view online)
- Has thanked: 647 times
- Been thanked: 856 times
Re: how to connect to different node's trough tcp ip
Thanks for posting that looks great. Have you tried using a second network comms component to establish the communications with the second device?
Hello BenR
I used another tcp_Ip component but no connection with the load at al . I think this would work if i had multiple network cards in my PC but unfortunately I don't have .
- power_suply_V_A_P_with_feedback_minderbelasting_TCPIP_keymapping_seconde_tcpIP.fcsx
- (54.9 KiB) Downloaded 825 times
- (view online)
hi all
I finaly figuered
it out how to connect to different node's trough tcp/ip and make it look "realtime" i start from scratch again .
now every node has +/- 750ms to speak to the main PC that controls everything .
A question to the developers : when i use the timer interupt the given info about the frequentie isn't right ? i had to go on my feeling wich frequentie works for me becaus the highlighte frequentie doesn't match the real frequentie.
I finaly figuered
- timer_fout.jpg (106.47 KiB) Viewed 10538 times
- realtime_strategieV1.2.fcsx
- why doesn't match the freq given the "real" frequentie"
- (35.24 KiB) Downloaded 732 times
- (view online)
Yes we are aware the simulated timer interrupt rate may be a bit off and one of our major goals for the next version is to try and improve this.
Well done on getting it working though and many thanks for sharing with us.
hi everybody
I encountered next probleme when running the flowchart in simulation my 2ddashboard ended up beining white
the only thing i can do then is close everything en start everything up again
thx again for your help guys
Greetings Ruben
Greetings Ruben
- simulator_V1.4.1_realtime_strategie_tcp_Ip_oké_output_Input_oké_update.fcsx
- (63.79 KiB) Downloaded 757 times
- (view online)
- white_screen.jpg (53.51 KiB) Viewed 10464 times
- Has thanked: 311 times
- Been thanked: 479 times
Hi.
I've tried simulating your program, but I've not been able to replicate the problem. Were you doing something particular when the error occurred or was there any error message reported?
