ESP32 Compiling error
- Has thanked: 772 times
- Been thanked: 831 times
- Has thanked: 245 times
- Been thanked: 257 times
Re: ESP32 Compiling error
Hi Martin
I think it's something like this. So I found an info about an offline-installer.
I will try it next monday
https://docs.espressif.com/projects/esp ... setup.htmlESP-IDF Tools Installer
What is the usecase for Online and Offline Installer
Online Installer is very small and allows the installation of all available releases of ESP-IDF. The installer will download only necessary dependencies including Git For Windows during the installation process. The installer stores downloaded files in the cache directory %userprofile%\.espressif
Offline Installer does not require any network connection. The installer contains all required dependencies including Git For Windows .
Hi to All
I used the offline installer. While installing there was no error
but if I compile to chip:
C:\Users\stefan.erni\Desktop\esp-idf>python --version
Python 3.8.7
The following Python requirements are not satisfied:
click>=7.0
pyserial>=3.0
future>=0.15.2
cryptography>=2.1.4
pyparsing>=2.0.3,<2.4.0
pyelftools>=0.22
gdbgui==0.13.2.0
pygdbmi<=0.9.0.2
python-socketio<5
kconfiglib==13.7.1
reedsolo>=1.5.3,<=1.5.4
bitstring>=3.1.6
ecdsa>=0.16.0
construct==2.10.54
esp-windows-curses; sys_platform == 'win32'
To install the missing packages, please run "C:\Users\stefan.erni\Desktop\esp-idf\install.bat"
Diagnostic information:
IDF_PYTHON_ENV_PATH: C:\Users\stefan.erni\.espressif\python_env\idf4.3_py3.7_env
Python interpreter used: C:\Users\stefan.erni\.espressif\python_env\idf4.3_py3.7_env\Scripts\python.exe
Traceback (most recent call last):
File "C:\Users\stefan.erni\Desktop\esp-idf\tools\idf.py", line 47, in <module>
from idf_py_actions.tools import executable_exists, idf_version, merge_action_lists, realpath # noqa: E402
File "C:\Users\stefan.erni\Desktop\esp-idf\tools\idf_py_actions\tools.py", line 7, in <module>
import click
ModuleNotFoundError: No module named 'click'
Build Failed
Autoclose turned off
LeighM
- Has thanked: 107 times
- Been thanked: 302 times
Try this ...
Run a Command Prompt
cd to the esp-idf directory e.g...
Then type/run
cd C:\Users\stefan.erni\Desktop\esp-idfCode: Select all
install.bat esp32-
LeighM
Hi Stefan,
Looks like a Python issue, in that the extra packages have not been installed, or inaccessible by the version ESP thinks it’s using.
Do you have more than one version installed?
Might be worth uninstalling all Python, then trying again.
Leigh
Leigh
jollybv
- Has thanked: 42 times
- Been thanked: 15 times
hi guys
Just from my experience when I created the esp-idf folder it automatically creates another folder espressif and puts the file in that when I forced it to install in the esp-idf without the espressif folder everything worked.
Hi Jollybv, Hi Leigh
@Jollybv You mean for the second folder (.expressif) you choosed the same folder (on Desktop esp-if). I will try that.
@ Leigh Here is the version of Python and ESP-IF Tools on computer 1 (the one where works well) I will see what version are on the other computer and check if there are more than one version of Python.
Hi Leigh
There is the same Phyton but there is a Phython Launcher on the bad computer
- ESP_IF.JPG (11 KiB) Viewed 11674 times
- Bad_Computer.JPG (15 KiB) Viewed 11674 times
