ASCII Protocol
steve001
Has thanked: 81 times
Been thanked: 30 times
ASCII Protocol
Post by steve001 »
Afternoon All,
Dose the Ethernet module support ASCII Protocol commands ? commonly used it Automated Test Equipment
2 examples of commands attched
IP Comminucation Protocol.pdf
(3.51 MiB) Downloaded 559 times
Has thanked: 292 times
Been thanked: 458 times
Re: ASCII Protocol
I believe it does, in that it can send and receive text. You will need to form the required strings in your code, send them and then wait for and read the expected response.
LeighM
Has thanked: 103 times
Been thanked: 302 times
Re: ASCII Protocol
Post by LeighM »
.. and it looks like it uses UDP (not TCP/IP)
steve001
Re: ASCII Protocol
Post by steve001 »
Thanks Leigh/ Steve
I will have a go later - are there any examples anywhere ?
Re: ASCII Protocol
There are examples in the wiki, depending on what component you are using. Also, there's a free course entitled "Embedded Internet" in the "Education" section of the flowcode.co.uk site that might be of help.
