ESP32 WROOM bluetooth programming
luibra63
Has thanked: 1 time
Been thanked: 4 times
Re: ESP32 WROOM bluetooth programming
Post by luibra63 »
hi Stefan
sorry, but where did you find your "esp32s_sdkconfig" file? is it inside
"C: \ ProgramData \ MatrixTSL \ FlowcodeV9 \ FCD \ ESP \ Batch"?
because mine is totally different. I attact the file in txt format
esp32s_sdkconfig.txt
(26.43 KiB) Downloaded 814 times
best regards
Has thanked: 245 times
Been thanked: 257 times
Hi luibra63
Yes that's the place and yes the file there looks different.
For your first time bluetooth better change the sdkconfig file in the project folder.
You can also post this file as .txt and will have a look if I can change it and post it again for you.
luibra63
Has thanked: 1 time
Post by luibra63 »
hi Stefan
finally I understood how to navigate through the folders and modify the "sdkconfig" file of the project with "idf.py menuconfig", only with this method the "sdkconfig" file is not overwritten, if I directly modified the "sdkconfig" file with notepad, when I compiled, the file was overwritten. I made the same changes as you. Unfortunately I can't program, the programming starts but then aborts.
were you able to program with this file?
I attact file
and attact error file compiler
a.msg.txt
(20.42 KiB) Downloaded 629 times
Best Regards
Hi luibra63
The config file should be fine now.
I suspect there is a little problem with your program.
Can you post the .fcfx file?
luibra63
Has thanked: 1 time
Post by luibra63 »
Hi Stefan
i attact file, it is very simple,
a.fcfx
(8.04 KiB) Downloaded 668 times
Beast regarsds
Hi luibra63
I changed your program a little and changed the sdkconfig file like you did.
and bluetooth it's working now.
A little hint about connecting: only send when connected.
Sometimes it is better to send A or B and not send all possible characters
And can you check in the project option if your programmer port is there.
a.fcfx
(9.05 KiB) Downloaded 522 times
luibra63
Has thanked: 1 time
Post by luibra63 »
Hi Stefan
A big THANK YOU, now my program works too, it was necessary to delete all the folders inside the project, recompile and edit the "sdkconfig" file again as indicated by you. Now I finally see that it works. THANK YOU again for your patience.
best Regards
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
For whom it may concern: the brownout settings are located here =>
Component config -> ESP-specific -> Hardware brownout detect & reset...
Brownout via ESP-IDF.jpg (141.48 KiB) Viewed 6797 times
