Flash W25 reading doesn't work
Osta
Has thanked: 1 time
Been thanked: 5 times
Re: Flash W25 reading doesn't work
Post by Osta »
When additional SPI devices are connected, the SPI settings have an effect on memory operation.
What if the devices are different?
Osta
Has thanked: 1 time
Post by Osta »
Osta
Has thanked: 1 time
Post by Osta »
And if you connect additional SPI devices, their settings affect the operation of memory.
This means that when I access the memory I have to change the settings for each device promptly.
Osta
Has thanked: 1 time
Post by Osta »
Erasing doesn't work
Proteus
Proteus
EraseChip Prot.jpg (156.05 KiB) Viewed 9729 times
Program
Program
EraseChip.fcfx
Prog
(22.99 KiB) Downloaded 586 times
Osta
Has thanked: 1 time
Post by Osta »
Erasing 4k does not work
Proteus
Proteus
Flow
Flow
EraseBlok 0.jpg (38.96 KiB) Viewed 9729 times
EraseBlok 0.fcfx
Program
(23.29 KiB) Downloaded 614 times
Osta
Has thanked: 1 time
Post by Osta »
Erasing 32k works
Proteus
Proteus
Flow
Flow
EraseBlock 1.jpg (40.08 KiB) Viewed 9729 times
EraseBlock 1.fcfx
1Prog
(23.29 KiB) Downloaded 632 times
Osta
Has thanked: 1 time
Post by Osta »
Recording probably works.
Prot
Prot
WriteDataByte.fcfx
Prog
(25.48 KiB) Downloaded 688 times
Flow
Flow
Osta
Has thanked: 1 time
Post by Osta »
Reading works, too.
Prog.fcfx
Prog
(25.89 KiB) Downloaded 592 times
Prot
Prot
Flow
Flow
Osta
Has thanked: 1 time
Post by Osta »
Erasing the entire block doesn't work either
Prog.fcfx
Prog
(23.46 KiB) Downloaded 556 times
Prot
Prot
Flow
Flow
Osta
Has thanked: 1 time
Post by Osta »
20 write / read iterations also works
Program.fcfx
Program
(28.44 KiB) Downloaded 626 times
Prot
Prot
Flow
Flow
