The period register is misleading on the AVR range as it's always fixed at 256, there no period control register.
Therefore, as the period on PWM and the motor shield only shows 0 to 255 and not 256, the frequency displayed will not be correct.
It's not anything you are doing wrong.
You should see a warning about the period control register when compiling.
running a DC motor using the arduino motor shield
- Has thanked: 707 times
- Been thanked: 768 times
- Has thanked: 431 times
- Been thanked: 647 times
Re: running a DC motor using the arduino motor shield
Hi Martin
Thanks for the clarification. I'll check the compiler messages later too.
peterhalloway
- Has thanked: 1 time
Hi Martin
I have updated flowcode reprogrammed the arduino but still the motor does not turn. I also did not get a compiler warning. I am sure there is something simple I am doing wrong?
Pete
Pete
Try the attached.
Do you have a logic analyser or scope? If so look at the output pin on the Uno, it should show a 50/50 square wave. If not perhaps try an led with a resistor in series. It won't flash but if you change duty to 255 it should then be brighter than 128. This will at least prove your Uno is functioning.
Try the attached.
- DC motor_Test_1.fcfx
- (9.97 KiB) Downloaded 519 times
peterhalloway
correction the motor is now running thank you can you please explain what I did wrong
