PIC16(L)F18446 missing PortB IOC on Interrupt Icon Properties
miggarc
Has thanked: 7 times
Been thanked: 4 times
Post by miggarc »
At least for PIC16(L)F18446
PortB Interrupt On Change is missing on the Interrupt Icon Properties
It only has IOC for PortA and PortC .
This is incomplete as we can see from this uC datasheet:
IOC - Interrupt-On-Change
All pins on all ports can be configured to operate as Interrupt-On-Change (IOC) pins
Can you please add PortB to IOC Icon Properties for this uC ?
Many thanks in advance,
Miguel Garcia,
Electronic Systems Developer
Has thanked: 478 times
Been thanked: 713 times
Re: PIC16(L)F18466 missing PortB IOC on Interrupt Icon Properties
Post by chipfryer27 »
I'm not sure if Flowcode supports that chip as I don't see it in the list. Did you perhaps mean 16(L)F18446?
If so, Section 15.5 of the data sheet Register Summary - Interrupt On Change states
"Note: PORTB associated registers as well as IOCCx6 and IOCCx7 bits are available for 20-pin or higher pin count
devices only"
Therefore IOC on Port-B is not supported.
miggarc
Re: PIC16(L)F18446 missing PortB IOC on Interrupt Icon Properties
Post by miggarc »
Yes... Off course ... I didn't noticed I wrote the wrong PIC name .
Sure it's about the 16(L)F18446 .
This uC is available only in a 20-pin or higher pin count because it has 18 IO pins .
Screenshot 2022-06-11 181444.jpg (47.65 KiB) Viewed 3991 times
So, Flowcode should have IOC on Port-B for this uC .
Miguel Garcia,
I appear to need new batteries in my calculator as I seem to have miscounted the pins on the "46" :)
It does look like it should have Port-B IOC capabilities and is probably just an oversight as you suggest.
Has thanked: 647 times
Been thanked: 856 times
Thanks for letting us know, I've made the changes for you and they should now be available via the library updates.
